Question about Whirlpool Dryers
Whirlpool lec6646a HEAT STOPS WORKING AFTER SHORT TIME
Can it be used without the fan?
If you want to get anymore useful life out of it, stop operating it without the fan.
Aug 18, 2015 | Whirlpool Microwave Ovens
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
Jun 05, 2017 | Heating & Cooling
Why does my dryer stop heating
Clean your vent!
Try running dryer with vent unhooked if still shuts off could be bad thermostat. Try running on timed dry instead of sensor dry, could be sensor circuit.
Aug 30, 2014 | Whirlpool Dryers
My whirpool oven is working but does not seem to be heating as it should I wonder if the fan is not working
magnetron do get week over time even more so if you do a lot of short time food reheat, the fan normally is used to cool the magnetron wave guide and if it stops working the over temp safety will trip and stop the magnetron from working
Apr 27, 2010 | Whirlpool MH1150XM Convection/Microwave...
My whirlpool dryer stopped working today and will not put out any heat, do you know what might be the cause? Model # leq9858pwo
Short answer if the dryer drum still runs, but there is no heat: 90% it's one or both of the heating coils. 10% it's the control switch or relay.
If the dryer will still start and the drum will still turn, find instructions for how to test the heating coils. The test for the coils must be done with the dryer UNPLUGGED! It will involve taking a panel off the dryer.
Nov 24, 2009 | Whirlpool Dryers
I have a Whirlpool gas dryer model #LGR7648KQ1. When I first start it it heats but after a short time it stops heating. It sounds like it is trying to start again but it will not.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
You need a flame sensor
Aug 03, 2009 | Dryers
No heat
Try testing the voltage across both fuses. The time you swapped fuses, and the motor ran without heat indicates to me that one of your hot leads is not getting voltage. On a three wire system, you should have two 110v leads and a common. Make sure that the cord is connected properly, and the same for the receptacle that you plug into. Test the receptacle as well for proper voltage and a good common ground.
Hope that this helps. Please repost if necessary.....Operators are standing by......!
Regards, --W/D--
Jul 18, 2009 | Whirlpool Dryers
Cleaning out our old Whirlpool dryer
Use a putty knife and about 2 inches in , insert the knife forcefully while pulling out on the top panel . Do this on both sides .
Jul 14, 2009 | Whirlpool Dryers
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
