Question about Makita BMR100 Radio
How do I turn off alarm on a makita bmr100? - Makita BMR100 Radio
Makita radio stoped working
mine shows 'E' on display. was sent away to be tested by Makita they said nothing wrong, faulty battery. bought new battery, still doesn't work. Makita not pulling their weight
Jul 04, 2014 | Makita BMR100 Radio
Can't turn down bass on makita radio
Try using a high pass audio filter soldered to the speaker terminals.
Jan 21, 2013 | Makita BMR100 Radio
I have a Makita BMR100 radio. Stock speakers are 3.25" 8 ohm with an 8 watt 8 ohm amplifier. I replaced speakers with better 4" 4 ohm but they're not really compatible with an 8 ohm amp. I...
Buy an 8 ohm speaker and wire it in series-parallel look up images of of combination series-parallel wiring this allows wiring all speakers and keeping the 8 ohm loaf on the amplifier. Should get more linear volume between speakers. Not sure if replacement is worth it, those speakers are pretty good and work well with rain and jobsite conditions. I am planning to install some 8 ohm half inch tweeters on my Makita radio and using the series parallel wiring. Plead note series-parallel wiring is not series wiring or parallel wiring. It is s totally different way of wiring it that uses both names.
Jun 02, 2011 | Makita BMR100 Radio
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
May 25, 2011 | Car Audio & Video
Need car adaptor for bmr100 12v to12v
As they don't make one you have 2 options.
1) Buy another Mains Adapter and Cigarette Lighter Plug, Cut the Cable & Connect to the BMR100 and connect it to the Cigarette Lighter Plug.
2) Buy a small (100W) 12V to 240V Inverter and plug your existing Mains Adapter into this. You'll get one from eBay for about £10.00 to £15.00.
May 05, 2011 | Makita BMR100 Radio
My radio wont turn on when using batterys?works fine with the power lead tho?
my makita radio will only work with the ac power adapter and not any of my battery's it says to change the back up battery's which i did and still the same thing? has this happened to anyone else?? is there a easy fix for it?
Nov 25, 2010 | Makita BMR100 Radio
Is the bmr100 ment to charge the batterys
the radio wont charge the battery pack
Sep 03, 2008 | Makita BMR100 Radio
Makita BMR100 Radio Logo
88 people viewed this question
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
