Question about Kitchen Ranges
Broan range hood 42000-k, light ok, fan stop all time. the reason?
The light switch works fine, light is on and off. But the fan always off no matter how to push fan switch (high/low speed and off).
SOURCE: Broan Allure QS3
The Problem is the wiring. Take the 2 screws retaining the metal plaque off underneath the filters. You will see the wires leaving the motor going into a "molex" plastic connector which connects two another set of wires going to the control board. Check to see if the wiring colors match from side to side of plastic connector. Ive only seen it happen once but it was exactly that. I do service calls for broan & Nutone
Jean-Marc
Posted on May 14, 2008
SOURCE: Broan Allure II
The problem is definetly the control board.
Part# R111638=$110.00. I do service calls for broan.
Inventex.com
Posted on Jun 14, 2008
  • 171 Answers
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: Broan Allure QS3 push button switches for lights not working
you need a new set of controls,
Posted on Feb 24, 2010
SOURCE: Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Posted on Mar 11, 2010
Light button blinking why
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Jun 22, 2014 | Broan-NuTone Broan Elite E661...
I want to change the filter on my broan 42000-k range hood. filter number 97006931, never done it before. help?
Look at this exploded view:
http://www.appliancefactoryparts.com/hvac/broan/423601.html
Part number 11 is a retainer clip.
Here is the instruction manual:
http://www.appliancefactoryparts.com/content/pdfs/137548-2.pdf
Page five, illustration 13, shows that the retainer clip is turned 90 degrees to release the filter, turned back to retain the replacement.
Here's a cut and paste of the manual:
"FILTERS
40000, 42000 & 42000D Hoods Only:
Remove aluminum filter by turning filter retainer to
one side. (FIG. 13) Filter should be washed once a
month in a hot detergent solution. Aluminum filters
are dishwasher safe. When installing filter, make sure
that filter slides under retaining tabs on back of fan
housing. Turn filter retainer so that arrows on retainer
point toward front and back of hood."
Sep 21, 2013 | Broan-NuTone Allure II QS230SS Kitchen...
Broan Allure range hood fan will not turn off, no matter which button is pushed.
The fan switch contacts are probably welded together or the actuator mechanism is broken. Your best bet is to replace the fan switch, probably with a similar type having a higher current rating so the new one won't also be susceptible to contact welding. If you have an industrial electrical supply dealer or electronic surplus parts store in your area, those would be good places to look for a replacement.
May 19, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Broan range vent fan not working; motor humming but will not turn, light works fine, not the fuse.
The motors will go bad from time to time. I would check Broan's web site
www.broan.com
or fill out this form
http://www.centralvacuumstores.com/fan_help.php
Sep 12, 2009 | Broan-NuTone Broan Range Hood Accessory
Hi shealy,
Thank you,
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Lighs
Saint...first...have a look at the bulbs. Make sure the bulbs are 'really' good and that the sockets are clean inside and undamaged. Second, the switch might be bad.
Nov 15, 2007 | Broan-NuTone Broan Range Hoods Deluxe...
Broan allure fan and light
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Oct 30, 2007 | Broan-NuTone AllureĀ® I WS136BC Kitchen...
Kitchen Ranges Logo
55 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
