Question about TPI Degree Slope Meter Indicator, For Dozer, Grader, Caterpillar, John Deere, Volvo
How do you read the side guage? - TPI Degree Slope Meter Indicator, For Dozer, Grader, Caterpillar, John Deere, Volvo
Fuel guage sometimes read empty when there is gas in the tank?
Check that there are no holes in the float. If the fuel is getting into the float, it will give a false reading. Another thing is to check the ground on the float sensor. If it's not connected tightly, it will create a false reading too.
Mar 03, 2015 | 2002 Mitsubishi Lancer
Coolant guage reading incorrect?
It is normal for your guage to to fluckurate a bit,
Oct 25, 2012 | 1998 Honda CR-V
GAS GAGE WANT STOP READING EMPTY WHEN GAS IS IN IT
To confirm if the fault is with the Rheostat float within the fuel tank or the fuel guage in the dashbboard, you can remove the wiring to the fuel tank float. If the guage reading changes- to full- then the guage is good and the fault can be a jammed rheostat which can be removed from the tank and replaced after draining the tank. The guage can be tested on the outside with a ground wiring to the plate of the fittings and as the float is moved the guage must show a change in reading. if not the voltage must be measured to confirm the working of the guage.
Oct 19, 2011 | 2001 Buick Century
Please, tell me what temperature suppose to be in ref. and freezer compartments.
Hello Leo.
The general rule is 0 degrees F in the freezer, and 40 degrees F in the fresh food section. The temps are best measured with a temp guage in a liquid. Digital guages are usually more accurate than analog. But, use what you have available, and if you can't quite believe the readings, ie ice cream is frozen, milk is good and cold, then move up to a better temp guage. Or, if you have two or three different ones, put them all in there and use the average.
If you think temperature adjustment is necessary after testing, make it very small and wait for a day to take another reading.
Hope that helps you.
fil
Mar 03, 2011 | Dacor Epicure EF48BDCB Stainless Steel...
Recharge air on a 1998 oldsmobile bravada
You didnt actually post a question so I will try to help. You need 134a refrigerant and a way to get it into the system. Places like walmart and Advance Auto Parts has what you need. Most diy kits have a hose to connect to the Low Pressure side of the ac system and a guage. The other end of the guage has a connector that fits on the can of 134a. Start the car, turn the ac on high, open the hood. Being careful of moving parts under the hood, connect the hose to the Low Pressure side of the ac and see where the guage is reading. Most are color coded. If it says it needs charged, squeeze the trigger until the can is empty and take another reading. Continue until the guage is in normal range.
Jun 23, 2009 | 1998 Oldsmobile Bravada
All my guages went dead...
Check all of your fuses under the hood, and under the dash inside jeep on the passenger side in front of the door, on side panel.
Jun 21, 2009 | 1997 Jeep Grand Cherokee
Instrument panel guages don't read accuratly
I have a chevy cav 03 and my problem is just in the gas guage and temp guage now i cant seem to figure out how to fix it but for a quick fix i have jut been pulling out the instrument panel fuse and putting it back in it seems to fix t
Feb 26, 2009 | 2000 Chevrolet Cavalier
Beeping Noise & Fuel guage not reading accurately
Could it be your back up sensor going off that is making the sonar sound?
Sep 08, 2008 | 2008 Mercury Mariner Hybrid
Ambient temp guage problems
The temperature sensor is located in front of the radiator on the passenger side. Replacements cost approx $25.00.
Jul 23, 2008 | 2000 Chevrolet Impala
TPI Degree Slope Meter Indicator, For Dozer, Grader, Caterpillar, John Deere, Volvo Logo
Top TPI Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a TPI Measuring Tool and Sensor Expert? Answer questions, earn points and help others
