Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50v500 blurry words, double picture
I have a Hitachi 50v500 it has about 1/2 inch blurr on words, and picture, i have just replaced the bulb, and every now and then the temp light comes on and the tv kicks off, don't know if this would have something to do with the double picture or not though.
Thank for your help
5 Suggested Answers
SOURCE:
cammykins
  • 149 Answers
SOURCE: Hitachi 50V500 double imaging -- makes you think you need glasses
I might also help to have the manufacturer help you step by step process. They can help direct you through the steps otherwise it shall also let you know directly on the manufacturers website [hitachi.com] A year back they used to have an interactive assistance approach but it appears they no longer are offering that.
How long have you had your lamp in there for? Also, have you hooked it up to another type of connection lately? If so, what is it?
Let me know those answers to better assist you. In the mean time you can also contact the manufacturer regarding this mishap to get the step-by-step over the phone or via their website.
I'm eager to hear how things work out for you. I wish you the best of luck with it!
Posted on Oct 28, 2008
  • 3 Answers
SOURCE: Hitachi 50V500 50 inch
you need to contact hitachi because its a manufacturer defect...its called the light engine if im not mistaken that makes it turn funny colors...about 300 or better to get it fixed or call hitachi and whine and complain till they fix it...
your welcome
Posted on Mar 18, 2009
SOURCE: Hitachi rear projection LCD with yellow blobs on screen
I have the same tv and the same problem, but my yellow is a cloud around the outside of the screen. My tv was recently moved, and a repair shop told me that sometimes in a move these tvs light engine takes a shock and causes a yellow "band" on the screen. I am hearing that these light engines are not cheap either. Hope this helps you.
Posted on Dec 03, 2009
SD Tech
  • 14553 Answers
SOURCE: Hitachi 50v500 LCD, at the center of the screen
If it is a redish oval it is not the bulb. Go to a black and white program and take a good look.
If it is the red or pink oval let me know and I will tell you what the problem is.
If this helps you rate this solution as I do this here for free.
SD TECH
Posted on Jan 09, 2010
Testimonial: "the color at the center is more of a light light blue."
I just got this hitachi 50v500 from a friend. We had to have a lamp fixed, but now the screen is blurry, like the ghost shadow problem I've been reading about. The repairman who replaced the bulb said...
There is a specific method for ghost adjustment on the 50v500.
Ghosting is most noticeable on lettering or with the set in the 4X3 format the edges will look somewhat double or have a ghost.
If this is what you have: I have the process which is done with the Hitachi remote to correct this. I got this from Hitachi who published a service bulletin on this problem for this model.
SD TECH
Mar 19, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50v500a lcd
the bulb is tierd
try setting RGB trhogh the menu button
May 11, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture shadow
Double check you cable connection. Also see if this occurs primarily on local channels. If it is only on local channels it is a cable connection issue. loose connector or moisture that has gotten on the screw threads of the cable connector due to the elements outdoors.
Apr 10, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Jul 11, 2008 | Xerox Office Equipment & Supplies
Hitachi lcd picture problem convergence issue
You need to contact an ISF certified calibrationist.
Apr 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Yellow at the top, double vision, blurr
Good Day, turott1;
You need repair in the convergence circuit, purchase KIT 10. You can buy this at B&D ENTERPRISES, at 1-800-458-6053.
Good Luck, big IRISH.
Dec 30, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
198 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
