Kenwood 1974 ka-6006 amplifier receiver right channel is louder than right. Nothing is hooked to it except my phone through the aux 1 input. (I've been told about shorting out the phono and mic plugs, could this help and how would I do this?)
gadget
  • 14 Answers
SOURCE: playing itunes through receiver
On the back of your tower you should have auxillary outputs that will go into your receiver. Get a connection going between the two ports and you should have perfect sound. The sound that comes out of your headphone output will not really have the amount of power that your receiver needs. Hope this helps.
Posted on Sep 15, 2006
techman
  • 3130 Answers
SOURCE: Need help connecting Receiver to TV, DVD, VCR players
Take the audio outputs on the TV set and connect up to the The video 1 inputs to the receiver, BUT use the audio part of the video 1 input and leave the yellow video input blank. Now turn on the TV set, put the TV set on a channel, turn on the receiver and select the video 1 input and you should have the TV audio coming from the receiver. Good Luck.
Posted on Jul 30, 2007
  • 54 Answers
SOURCE: KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
BIG RED
Posted on Nov 03, 2007
mixmaster
  • 626 Answers
SOURCE: Cannot Find Aux On Kenwood KDC W3037A
You have to ENABLE to AUX source thru the settings menu.
Users manual is HERE.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 24, 2007
  • 518 Answers
SOURCE: kenwood receiver, and the mic input problem
Does the gtr still work on the unit? The mic jack may be bad / dirty and not routing regular audio. Try plugging the gtr cord in and out a few times. Or inspect the jack itself for tarnish, bad solder joints. Fine sand paper can be used to clean the contacts on the jack, if it's not a sealed jack.
Hope that helps...
Geno
Posted on Mar 24, 2008
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
I have a Kenwood integrated amplifier ka 791 how do I hook it up to a Sony receiver
Use sony recording line outputs to feed the aux input on the Kenwood.
Jun 12, 2015 | Sony Audio Players & Recorders
Kenwood how to connect
You need a stereo mini to RCA cable to connect the laptop's headphone audio jack to the Kenwood. Here is an example of one below. They are very common and available at just about any electronics store for a few bucks.
http://www.amazon.com/Gemini-PH62089-Stereo-Mini-Male-RCA-Male/dp/B0001GAOE0
The Kenwood receiver should have a number of red and white "RCA" audio connectors on the back.
Just connect the RCA portion of the cable to a spare input. They should be clearly marked on the back of the unit and color coded (red for right channel and white for left channel). But it really doesn't matter if you mix the right and left up, it will still make sound.
EX:
Most receivers will have inputs that are labeled "CD" or "Aux" that you can connect any audio source to.
If you connect your laptop or an MP3 player to the audio input connections labeled "CD" behind the Kenwood receiver, you can listen to the device by selecting the CD as the source.
It is really easy!
May 04, 2014 | Kenwood VR-305
Kenwood ka 7x
salut a tous quelq'un a un amplificateur kenwood ka x7 je veut connaite les tronsistors qui porte cette amplificateur le mien etait enlevr je connais pas les refferonces je demonde de l'aide et mercie beaucoup a +
Oct 05, 2013 | Televison & Video
Dead Kenwood Home stereo Amp. KA-2002
Some says it is only dead when it is buried.
Open it up and check, ( Be sure it is unplugged)
Only if you feel you can DIY or have a tech do it for you.
Oct 06, 2012 | Kenwood Vintage Model Ka-6006 Stereo...
Describe your kenwood manual "ka
Hi, Yes it is safe to leave this connection unhooked. The system control is what the stereo uses to remote control a cassette deck,cd,turntable etc... using the amplifier separately should be o.k. I hope this helps, good luck and thanks for choosing FixYa-Prodzilla
Apr 20, 2011 | Audio Players & Recorders
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Kenwood system with tuner, cd player, casette player,intregrated amplifier and stereo power amplifier
This website sells the owners manual for $9.99 and the service manual for $14.99 your stereo:
Here is the website:
http://www.user-manuals.com/advanced_search_result.php?keywords=KA-996&x=11&y=15
Hope this helps.
Could be too many different reasons for no/low output. My 1st guess would be the output transistors, but that again is guessing without knowing more info about the receiver.
Hopefully, its is something simple like the way it's hooked up, or if you have the wrong channel selected.
Good luck.
Feb 02, 2008 | Audio Players & Recorders
Aux input not working for mp3 player
Hi to you all. CAN YOU HELP ME? i have peugeot 206 and i have new kenwood CD MP3 and i also have aux input but I cant get any sound to come out at all?
Nov 04, 2007 | Alpine CDA-9883 CD Player
19 people viewed this question
 Grubhead
Grubhead
