Question about Mitsubishi WD-73640 73-Inch 1080p Projection TV
My mitsubishi wd-73640 73 inch tv picture is really dark now. could it have blown a bulb?
SD Tech
  • 14553 Answers
SOURCE: picture on my mitsubishi wd 60737 is dark. i have increased the brightness but picture looks like a night time scene
A few things occur to me, if Lamp not recently replaced (2year average life) it may be nearing the end of its life.
Just a few models (not sure if this is one) use two mirrors where most just have one large mirror.
If the issue was gradual you may have the two mirror set, one tiny mirror at bottom of screen area points up and reflects the image into the large mirror in the back of the set which puts it on the screen to view.
If your model has the two mirrors the little one will be coated with dust and such and cuts brightness up to 70%
You can call Mitsubishi and ask if your model has two mirrors or one, if Two mirrors and they will not tell you how to get at them I can.
Let me know if you need more help.
Posted on Dec 12, 2012
Testimonial: "AWESOME and im calling Mitsubshi right now. Thanks for you assistance. "
SOURCE: Tv brightness
I just bought an e 62525 on craigslist for $300 dollars. The guy had it in his garage because of a degraded picture... white out haze and virtually no black ... I surfed for similar issues most referring to the light engine. However; going back to basics. I removed the front panel assembly (approximately 16 screws including the center panel surrounding the card/rca ports in the front). The main mirror was spotless (in itself missleading) but the projection lense and the smaller mirror were frosted over with 3+ years of fine dust. I cleaned them with a simple cloth. I also noted that the foam insert surrounding the lense had gaps due to age which allowed excessive light sepage (the white out problem). I repositioned the foam as best I could. Then simply stuffed a black cloth over the foam but firmly arround the lense (keeping the foam intact as well). This blocked "all" light sepage. Bottom line is that I now have a picture quality that is flat out incredible! This is one bad mutha (shut yo mouth) tv. P.S. I'm just an average guy with an electric screw driver.
Posted on Nov 27, 2008
  • 159 Answers
SOURCE: Color
If the tv looks now dark this is the first symptom of a lamp replacement (refer to the user's manual to do this job) and get a Mitsubishi original replacement.
the best picture setting (when the lamp is back of course) depends in the light of the room.
Now if after replacing de lamp and playing with the settings and the screen still pale, dimm, not enought color. a cleanning in the reflexion area is needed. (technican job)
Posted on Apr 17, 2009
Slinteriors
  • 8617 Answers
SOURCE: green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Posted on Jul 22, 2009
  • 8457 Answers
SOURCE: I have a mitsubishi 60
The tv projection lamp have problems,it shorting out some how.That why,u have a dim picture.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.New tv,call mitsubishi for a warrenty repair.
Posted on Oct 18, 2010
My picture went very low where you can barly see it
By low, do you mean dark that you can hardly see a pic. If so then the bulb is going out, if its the same kind of tv as mine. Go on Mitsubishi site, and order new bulb, they are pretty easy to replace, instructions on youtube.com too!
Jun 16, 2014 | Mitsubishi WD-60738 60-Inch 3D DLP HDTV
Tv is getting dimmer
Brenda, Your projection bulb is about to die. Go on eBay, so a search for the bulb. Only buy a genuine Mitsubishi bulb to replace it. Or order one of these;http://www.shopjimmy.com/mitsubishi-wd-65c9 Get one of the "assemblies".
Removing and replacing the bulb unit is SUPER easy. Unplug the TV!! You unscrew the one screw on the litle door and the lower right, back side of the TV, then unscrew those two screws that hold in the unit, and slide it out. Slide in the replacement, and tighten everything up. Put the door back on, and plug it in.
Nov 25, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
I just replaced my bulb on my mitsubishi wd-65736 but picture is still dark looking and the bulb stays lit up after we cut the TV off. Could I have hooked the two wires up wrong?
This site lists your service manual for $7.99
https://www.completeservicemanuals.com/mitsubishi/dlp-projection-television/wd-65736-service-manual/prod_1408.html
This site claims to have a free PDF download, but the "free download" link throws you to www.tradebit.com, which sells the service manual (as a downloadable PDF file) for $7.99
http://www.promanuals.com/serviceparts/mitsubishi-wd-60735-wd-65735-wd-73735-wd-65835-wd-73835-wd-60c8-wd-65c8-wd-73c8-wd-65736-wd-73736-service-manual/
This site sells your TV service manual for $5 as a .PDF sent to your email:
http://tv-part.com/index.php?target=products&product_id=1369
If you can read/use a service manual, $5+tax is a lot better than $hundreds for a new television. Or- buy the downloadable manual, and give it to your favorite electronics friend to peruse. The darkness coming from the new lamp might bespeak of a power supply problem, or a poor connection between the lamp and the power supply. The fact that the lamp module stays on after it should go out also says power supply problem.
In the worst case, keep both your lamp modules (they're probably both good), and sell them online to help defray the cost of a new television.
Sep 30, 2011 | Mitsubishi WD-65736 Television
I have a mitsubishi 60 inch tv model wd-60c9 and i purchased it this year ..aug 06 2010 and the picture has became very dark..i am using hdmi conection and purchased new and better cables..issue still dark
Oct 18, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL MIKEKIMA@HOTMAIL.COM
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
WD-62627 dark pic, contr. and bright. @ full..newer bulb.
You could try to INITIALIZE the tv by doing the following:
1) turn on TV
2) from the remote press MENU 2,4,7,0 then ENTER
3) TV will state that is INIATIALIZING
4) press the RESET BUTTON on front of TV.
5) hopefully it's fixed.
Sep 20, 2009 | Mitsubishi WD62627 62" HDTV
Dark picture problem
there are 2 mirrors did you clean both there is one down in front near the light source when front screen removed lean in and look down there is another smaller mirrorclean it
Jan 02, 2009 | Mitsubishi WD-62327 62" Rear Projection...
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-73640 73-Inch 1080p Projection TV Logo
462 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
