Question about Aiwa Audio Players & Recorders
Where can I get new tape Drive belts from for AIWA NSX-D30?
The Tape player keeps on making a clicking noise when I hit play. The belts that make it run broke. Does any one know were I could go to, to get a replacement belt. Was wondering were I could go to get a replacement belt The Model No. Is: NSX-D30 AIWA
chie-chie
  • 98 Answers
SOURCE: Cassette Player
  • very easy.. if your motor 12 v or 6 volts...for 12 volts motor buy an ic "kia 7812 this parts is voltage regulator with 12 volts 1a output..7806 this parts is volt.reg with volts 1a output..7803 3 volts output etc. etc.
  • input 1st terminal
  • ground mid terminal
  • output 3rt terminal
same a transistor.
Posted on Feb 05, 2008
  • 518 Answers
SOURCE: tape deck is broke sounddesign model 5959
If the motor is running but the belts are not, then they are probably shot. You can buy belts by size or buy a belt kit at MCM Electronics.
If the motor is not running it could be 2 things: 1. A bad motor or voltage to the motor.... 2. A bind. I've seen the grease on the capstan bushing get old enough to turn into a very hard tar. So check the motor and capstan for freedom of movement.
Hope that helps you get it working...
Geno
Posted on Mar 26, 2008
  • 6 Answers
SOURCE: aiwa nsx-9000 is eating my tapes
Well 1st unplug it then you can start by qtip cleaning, blowing internal maintenance service. But for the most part regardless of use or age whenever there is gears, bands moving parts which in time get worn, Now this is were keeping clean extends life, So time to shop for a new 1 because repairs and part availablity exceeds the value,of your problem
Posted on Mar 04, 2009
  • 104 Answers
SOURCE: Cassete deck will not work, I put a tape in deck 2
I have a sony twin cassete deck and the same thing happened to mine , it turned out to be the rubber belt inside was broken so i just bought a pack of assorted belts for $7.97 and replaced both belts .
Posted on Jun 05, 2009
welcomejee
  • 10594 Answers
SOURCE: aiwa nsx-d30. How do
Press power button on unit to turn Off unit (standby mode) then press PAUSE button on unit and use MultiJog to set hours then press PAUSE to select minutes set.
Click Aiwa Support to download user manual copy of NSX-D30 and check page-9 for more details to set time without its remote.
Required remote for Aiwa NSX-D30 is available in Remotes.com for $38
Hope these info will help you.
Thanks.
Posted on Dec 11, 2010
How can I open AIWA NSX-A508's tape door?
When the deck is clicking when you first power it up, reach inside and turn the capstans by hand and this should disengage the tape head assembly. The problem is the drive belts are slipping and need to be replaced. The door will not open because the head is engaged.
Feb 12, 2013 | Aiwa Audio Players & Recorders
Cds skip on first songs tape deck eats tape aiwa 3300
I AHVE THIS SAME SYSTEM, YOUR LENS ON THE CD PLAYER NEEDS TO BE CLEANED, AND THE TAPE ROLLER AND CAPSTAND NEEDS TO BE CLEANED, OR MORE THAN LIKELY, THE BELTS NEEDS TO BE REPLACED.
Nov 30, 2012 | Aiwa NSX-A777 Shelf System
I have a nsx-a508 unit,the 2nd tape deck got stuck i was able to open it but now neither deck plays and the cd player did work when this happened originally but does not work now ,the lights all come...
I think I can help you with the tape part, but as for the CD, that's a whole different story.
First, you should reset the unit by holding down the stop button (clear), and then pressing the power button. Everything stored in memory after purchase is cleared, including the radio stations, clock, etc.
Check if deck 1 is now playing.
I had a similar problem with my AIWA NSX-AJ310, and after some digging up, I realised that the belts were busted. They're not hard to replace though, unless you don't trust yourself to replace them. If you don't, let a qualified technician see about that for you.
The CD player in my system has retired also, so, we're in the same boat as with regard to that issue!!
Hope my solution was helpful!!
JaHa
Jun 21, 2011 | Aiwa NSX-A505 CD Shelf System
I have a AIWA brand music system model NSX-V70. It has Tape--Tuner--Video/Aux--CD facility. Problem: 1) CD changer is not operating, it is locked, not opening as a result can not play any CD or DVD. It is...
It is possible that your Cd and teh tape section has a belt problem. The loading belts of the cd and the tape transport is worrn out and results in non action. Since there is no drive the cd mechanism nor your tape mechanism will work. If you have a help around ask them to open the top cover, remove the tray and look inside for the loading motor of the CD. replace and keep the Cd section out. by removing the connecting corrds very carrefully. ZThe tape deck mechanism is within and you will see the belt worn out. The front panel and the deck assembly can be taken out and the belts can be replaced. Attempt to do the job only if you are familiar with electronics other wise get help from a good reputed service shop to replace the motors. However this is not a expensive work but must involve great caution not to damage any parts with inexperience. I hope you understand and find this helpful. Pune is a great place and if you look around find a good sincere technician to help . Good day
Mar 24, 2010 | Aiwa Audio Players & Recorders
AIWA CXNMT 520 CD/TAPE/RADIO PLAYER
Click Aiwa Support to download required user manual for CX-NMT520 (NSX-MT520) that has all info about this sound system.
Thanks.
Dec 18, 2009 | Cameras
When playing a tape there is a clicking noise, its very fast (think running past a chain link fence and holding a stick against it) the tape will play, and will pop out fine, but the clicking noise is...
Something is inside the cassette well. Or one of the reels is slipping. Reach in and manually rotate each reel hub to see if you can feel any reason for a click.
Nov 07, 2009 | Aiwa NSX-AJ20 CD Shelf System
Tape deck problems Aiwa CA-NSX777
Tape drive mechanism requires service (cleaning and lubrication) and might need replacement of drive belts. Of course its qualified tech job.
Jul 25, 2009 | Aiwa NSX-A777 Shelf System
Cassete deck will not work, I put a tape in deck 2 and hit the record button and all it did is started to make a clicking noise. Next I tried to take tape out and the door would not open. I forcefully...
Jun 05, 2009 | Aiwa NSX-A767 Shelf System
Tape door won't open and decks won't play
mechanisum stucked.
remoove the cover and change the all belts.
nuwan.
Oct 21, 2008 | Aiwa NSX-AJ20 CD Shelf System
Cassette Player Stopped Working
In all likelihood the Drive belts have snapped. Get them replaced.
Sep 24, 2006 | Aiwa XR-C3RW Shelf System
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
