I need a univesal remote control that works with innovair mini split
  • 147 Answers
SOURCE: heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Posted on Sep 30, 2008
MNTECH
  • 1543 Answers
SOURCE: Got mini split, lost, remote control, bought
Don't know a code for a universal remote, but you can order a new remote from an appliance parts supplier. If you have the model you posted under, the part number would be WJ26X10152 . (about $25) Make sure you have your exact model number from the model / serial number tag off the product to make sure you get the correct remote.
Posted on Jul 29, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
Myminisplit
  • 11 Answers
SOURCE: Troubleshooting my LG Art Cool Mini split
If the units are close to each other they will both read the same setting. You just have to get the remote really close to the wallmont air handler you want to command.
Posted on May 14, 2010
SOURCE: I have a bondaire ULB 18HP mini Split Air
I purchased a universal remote CHUNGHOP K-1028E on ebay for this unit but the bad news is it only does basic functions and its in Celius.
Functions that work
On/off
heat
cool
wind/fan speed
mode
Led light
3 flap settings
code is 348 and 453
I also have a harmony one remote and tried learning the original remote functions but doesn't really work properly
GOOD LUCK
Posted on Sep 28, 2010
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
Jul 25, 2016 | LG LS-K1830CL Cool Mini Split Air...
I have panasonic tv tc-2120t i want univesal remote code
Universal remote codes for Panasonic TVs are: 0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070. Check this for more codes and other details to different remote controls.
Jan 02, 2013 | Televison & Video
My innovair ac split control damaged where can I turn it On without a control?
mi remote control is damege how can turn it on with out the control ????
Jun 08, 2012 | Heating & Cooling
Ge univesal remote codes
Go to GE.com's website and search under your remote control's model #. It is likely they have the documents there.
Dec 12, 2011 | Universal Remote Control GE174Universal...
I have a Innovair Prestige mini split and I chance the braker switch but the airconditioner did not turn on. How can I resolve this?
you need to make sure you have power going to it and coming out of it why did you have to change the breaker it could be more serious problem inside the system
Sep 11, 2010 | Heating & Cooling
Jul 29, 2009 | GE AJCQ08ACB Air Conditioner
E4 in an innovair a/c
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
It sounds like you have a freon leak and may need a charge. When there is a leak, the compressor will run for awhile but without the proper charge, it will heat up and kick on on thermal overload. After the compressor cools, the unit will come back on. Have the unit serviced by a professional.
Jan 09, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
