Question about AOC Televison & Video
Why does the menu and channel display keeping poping up while watching tv?
Using a scart lead but while watching the menu and channel display keep popping up constantly on screen, manual buttons do not work when this occurs
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 83 Answers
1. Remove the batteries from your remote to ensure that is not sending signals to the TV.
2. The TV may have an internal problem and might need repair.
Posted on Jun 25, 2016
  • 223 Answers
SOURCE: menu screen
It could be dirt/dust has accumulated behind the buttons causing a false contact so it looks like a ghost is operating your tv making things appear and disappear.If this isn not the problem then there is a faulty component on the board where the buttons are located. If you are able to do the cleaning of the buttons yourself use a cleaner that de-greases as wel and make sure everything is bone dry before re-assembly. If not find a competant technician. Hope this helps.
Posted on Oct 01, 2008
tvguy171
  • 106 Answers
SOURCE: menu screen pops automatically while watching tv
Go to the philips consumer website, input your model. You are going to look for current software updates. Download the the software to a memory stick. Once downloaded, insert memory stick into USB port on TV. It will upgrade automatically and your problem will be solved. Let me know if I can be of further assistance
Posted on Dec 24, 2008
SOURCE: Invalid Input-turning off seeting
I have the same problem in the office, but, not at home. I believe the IR sensor is confused by office florescent lighting, which has an unperseptible 60-cycle flicker not charactoristic of home incandescent lighting. Energy saving compact florescent probably have the same effect.
I have attached a dark tube over the sensor with relative success. This cluge is an unfortunate compensation for poor engineering because of the reduced angle of reception (the remote has to be directly in front of the sensor).
Posted on Jan 08, 2009
  • 108 Answers
SOURCE: black box keeps poping up in the middle of the tv
your closed captions are turned on and in the text mode. turn them off or select cc1 to view that captions
Posted on Jan 09, 2009
tlm931
  • 273 Answers
SOURCE: The menu screen keeps popping up?
there is a firm ware download for many of these sets at philips site that will correct this problem
Posted on Oct 25, 2009
Testimonial: "Found it, thanks http://tinyurl.com/PhilipsTVupdateInfo"
Why does menu keeps poping up non-stop when watching tv but when sky box is paused this does not happen, why????
Can you use a digital camera to view your remote to see if it is sending out signals when it should not? It might have dirty buttons from food or other dirt. This can cause it to send signals even when the buttons are not being pressed.
May 11, 2014 | AOC Televison & Video
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
How do i connect the vcr to the tv so it records on the channel i want. i tried recording but was a different channel. i do not have the remote for the vcr
If the TV has a scart socket and the vcr also, you can connect it that way, with a scart lead. Then all you need do is press the channel button on the VCR till it reads AV. There may be more than one AV socket so use the one with the connection of the scart lead, it should say on the scart socket what it is. IE: AV1. All you need do is set the channel on the TV you want to record, the press record.
You won't be able to watch another channel though while recording.
Some TV's with multi scart have options for AV settings or recording from the TV, so check these out.
Consider buying a universal remote.
Feb 11, 2010 | Emerson EWV603 VHS VCR
How do i get my funai vcr to record from my freeview box. I can only record through my analogue channels. I have a funai vcr either 31B-750 or 31B-754 (PDC) and the freeview is an Astratc TopD2
hi, how is the free view running through the video?
Option 1(this is the most complicated way if you are using scart lead or the three color leads then skip to option 2)
if you using the normal arial socket ie arial from roof goes into free view then from free view into vid then vid into tell then what you need to do is make sure on the free view that you have a menu screen on the screen either tv guide or something that will stay on their.
Now put the video on a channel you dont use say 6 then you need to use the video remote and then enter the setup mode and then start the scanning process to look for the signal keep going until you get the menu screen that you opened on the free view then store this as channel 6 on the video.
Now when you want to record from the free view you put the video on channel 6 and put the free view on the channel you want to record.
Option 2:
If you free view box is using scart leads and has two scart lead outputs on the back, ie one for the telly and the other for the video, if you have it like this then plug telly scart into telly and video scart into video.
Now in the back of the video you should have scart lead coming from the free view, and maybe one coming from the video into the telly
If this is the case then all you need to do to record off free view is switch the video on the when you choose what channel you want to record instead of choosing 1 to 5 for normal channels you need to select av scroll down the channels past zero if you have not got av button once av is selected you should then see the free view channels try by pressing guide on the free view and put the video on av this should then let you see the free view via video if not dont worry press record for 5 min then rewind and press play it should now play back the free view you was just watching.
Option 3 now if you have it set up any other way just let me know how then i can assist you further ok.
If you have any problems following my instructions then just post me a message back and ill be glad to assist you further ok.
Many thanks for using fixya.com
Nov 18, 2009 | Electrical Supplies
Black box keeps poping up in the middle of the tv
Jan 06, 2009 | Insignia IS-LCDTV32 32 in. Television
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Watching digital tv using a Panasonic DMR-EZ47VEB
PLEASE NOTE THIS INFORMATION COVERS PROBLEMS FOR ALL DEVICES CONNECTED UP BY STUPID scart LEADS. I HOPE IT HELPS EVERYONE.
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Oct 14, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
