Question about Poulan "Poulan" Push Mower
How to replace pull cord on poulan pro lawnmower
  • 582 Answers
SOURCE: Poulan Pro lawnmower (Briggs and Stratton 128 cc
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Posted on Sep 17, 2009
  • 430 Answers
SOURCE: Poulan Pro Hydro 18.5-42 riding lawnmower- no
First check that the purge valve is not engaged. Usually a small rod sticking out the back plate of the unit toward the right side. It should be pushed in.
Next check your drive belt. Best bet is to remove the deck and lay under the unit. Check for locked up pulleys and that the belt is seated properly on all the pulleys and that the belt is not stretched, cracked, or burnt. Make sure the belt gets taught when brake/clutch is released.
Lastly, there are keys in the drive axles. I have never seen one fail but they do get lost on occassion when the wheels are removed.
Posted on Dec 10, 2009
SOURCE: I have a Poulan Pro Lawnmower M# PR600Y22SHP and
http://www.mccullochpower.com/node6605.aspx
Posted on Jul 19, 2010
Knucklebstr
  • 222 Answers
SOURCE: How do i replace pull cord on lawnmower?
The best way for me to tell you is to show you a video on YouTube. There are a million of them, but I'll link you to 2 of my favorites because there are actually two different ways of doing it, depending on your setup. Click the links and enjoy; best of luck to you.
http://www.youtube.com/watch?v=GyjQir3b3xI
http://www.youtube.com/watch?v=i3ZMVFi0yqY
Posted on Jul 02, 2011
Knucklebstr
  • 222 Answers
SOURCE: poulan pro w/ 550 series
Your carburetor needs a good cleaning or a rebuild kit, depending on its condition once opened up. There are tiny holes (jets) in there that easily get clogged or gummed up with today's crappy gas (ethanol). This is the problem with 90 percent of the machines I work on or fix. If you don't know carbs, then I recommend you take it to a professional and have the carb done (30 to 40 USD, probably), but it should run like new, once this is properly done. If you are a "do it yourselfer". then you can find plenty of videos on youtube to help you get started. Just pay close attention to what goes where when you take the linkage apart. Trust me, do not leave it to memory; take photos. Best of luck to you.
Testimonial: "Much appreciated. Giving me an idea of what to look for as well as where I can go for further information is extremely helpful. Thanks. -Jake Towley"
Poulan pro 295
Not sure if this will work for you but I had a lawnmower with too much compression and my mechanic said i had put the wrong spark plug in which was too long and that caused too much pressure when trying to start I almost ruined the engine. I put the proper plug in and seems to work ok now.
Jan 06, 2018 | Garden
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan 18" PP4218 Pro 952051338 It has fuel
you may need to clean your sparkplug, or replace it
Aug 05, 2011 | Poulan 952051338 18Inch Chain Saw Chain 38
Jul 01, 2011 | Poulan Pro 22" Self Propelled High Wheel...
I have a Poulan PRO LINK PP 335 and the pull rope is only coming out about 8 inches. It's stuck...what should I do?
Remove the starter and pull the cord, if the cord still only comes out so far it is either the cord is too short ( replace the cord ) or the rewind spring is coil bound ( release some of the tention )
Apr 23, 2011 | Poulan Garden
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
Will not start
completly disconect self propled belt or gear should be able to mow til you fiigure out whats up with self pro some thing is jamming selfpro ps if you have to turn it upsidedown kill switch on
Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
i have a 950 zx poulan pro lawn tractor. it will start but when i release the brake it cut off . i can start it up with out sitting in the seat.
Jun 14, 2008 | Dryers
Poulan "Poulan" Push Mower Logo
193 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
