Question about Acer Aspire L100 PC Desktop
Why does Acer l100 PC shut down? - Acer Aspire L100 PC Desktop
    Habit-Forming:
    New Friend:
  • 110 Answers
You need to service you pc ar laptop. The cpu needs to get new thermal compound every 3 to 6 month's add me on facebook Nic fourie for complete guide to how the service your own pc or laptop
Posted on Sep 20, 2016
bibleman01
  • 334 Answers
SOURCE: Acer Aspire L100 PC Desktop
Get an external network modem that uses usb port that's my advice because sometimes we can search forever lookinf when we can enjoy it already.
God Bless Greg
Posted on Nov 17, 2008
SOURCE: sudden death acer l100
Ive had the same problem died on me and wont switch on but I found itas a different capacitor on the board same value as the one mentioned I replaced the 1st one and stikk didnt work so replaced the 2nd & 3rd cap as they looked swollen and it worked, I couldnt find a 6.3 1000uf so I used 63v 1000uf slightly larger but fitted ok,
I dont know if it was the 2nd or 3rd cap that was faulty as I replaced both at the same time.
See the image attache and you can see where they are located also you can see they are swollen
Oh forgot to mention make sure you use high temp caps to replace them ie 105cfdc3128.jpg
Posted on Jan 20, 2009
  • 73 Answers
SOURCE: acer l100 will not restart
If it's just not loading Windows, restart into Safe Mode. Instructions here:
http://www.bleepingcomputer.com/tutorials/tutorial61.html
Restore from a system restore point created before you ran the PC tuneup software. Instructions for Vista:
http://bertk.mvps.org/html/restoresysv.html
Instructions for XP:
http://techpaul.wordpress.com/2008/09/04/how-to-use-system-restore-to-fix-windows/
Posted on Feb 06, 2009
  • 10 Answers
SOURCE: acer L100 wont power up
bad PSU
Posted on Aug 25, 2009
Testimonial: "thanks for that about the psu, but i have been told by a local pc repair guy that psu's are as good as rockin horse poo to get cos the L100 is mini?"
My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
May 14, 2010 | Acer Aspire L100 PC Desktop
Thanks for the response to my Acer L100. have checked the cables and they are fine. have noticed the fan doesn't start up when the computer is switched on....could this be the problem???
The CPU fan should turn on when the PC is powered on, and then it usually slows down until the workload on the processor causes it to heat up, then the fan spins faster, it might also be a power supply issue, but if your able to boot and its giving you messages and not shutting down then you should re-install the operating system.
Nov 18, 2009 | Acer Aspire L100 PC Desktop
PC automatic shutdown
logon.ddl has been missing u hv to reinstall ur operating system
formate ur pc it will solve ur problem
Jan 29, 2009 | Acer Aspire L100 PC Desktop
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Acer l100 shut down
You can buy a Laptop cooling pad for less than $40 from most any computer store.
Oct 26, 2008 | Acer Aspire L100 PC Desktop
Possible overheating problem for Acer Aspire mini L100
I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
Sep 26, 2008 | Acer Aspire L100 PC Desktop
Acer l100 cuts out for no reason
I suggest to remove the program for itunes, i think it did make a mistake  to the operating sistem
Dec 06, 2007 | Acer Aspire L100 PC Desktop
Computer will not shut down
I have not switched to Vista, but I would try starting the Task Manager (right click on the task bar and select task manager). Then I would select the Processes tab and start killing processes to see if you can track down which one is causing your problem. Assuming you can narrow this problem down to a single process you'll at least have a fighting chance at solving fixing this.
Good luck.
Nov 19, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire L100 PC Desktop Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
