Question about Iview Tablets & eReaders
My iview supra tablet turns on but never passes the android logo to the main screen. is there a way to get to my main screen?
  • 3940 Answers
SOURCE: my binatone homesurf tablet is stuck on the home screen and wont do anything can you reset it
Sounds like it needs a reset.
The Binatone Helpline is available from 9.00 am to 5.00 pm, Mondays to Fridays, please call0845 345 9677 for UK+491805938802 for EuropeAustralia customer service number 1300 768 112 or email to service@shriro.com.au India customer service number +91 7503011385 or email to assist@binatonetelecom.in
http://www.binatonetelecom.com/binaries/content/assets/binatone/products/android-products/homesurf-7/pdf/homesurf_7user_guide.pdf
The manual has very limited troubleshooting, so it looks like you'll need to call them.
Posted on Oct 25, 2011
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
uniman9310
  • 190 Answers
SOURCE: Onda v711
You need to perform a hard reset on your Onda V711. Here`s how: You can perform a hard reset by booting into a special recovery mode. First, ensure your device is fully shut down. When the tablet is turned off, keep home button pressed.
Now turn on tablet while still holding the home button.
When white android figure appears, release both buttons.
You will get into recovery mode, you can select "restore factory settings" there.
If that fails, try flashing new firmware.
Posted on May 03, 2013
SOURCE: My iview 7" tablet fell and the screen is cracked. Can it be replaced and work like new again
Yes it will work again but the crack will still be there.
Posted on May 21, 2013
How to bypass pattern lock screen when you forgot the pattern
reset the whole machine to factory lose all apps
Jan 05, 2017 | Tablets & eReaders
It is stuck on the logo android is there anyway to make the tablet work again
Second one in three days. Seems a know issue.
  • Android tablet stuck on Android Logo Fix - YouTube www.youtube.com/watch?v=B_bJeLnlClE
    • BY RICARDO GARDENER
    • 9 MIN
    • 237K VIEWS
    • ADDED 2014-08-13
    Video embedded · Learn how to fix your tablet that is stuck on the Android logo or ... Learn how to fix your tablet that is stuck on the Android logo or Android start ...
  • How to fix an Android phone if it is stuck or frozen on ... www.smartmobilephonesolutions.com/content/android-stuck-on-samsung ... or it boots up to its Samsung logo then freezes, ... How to fix an Android phone if it is stuck or frozen on the Samsung logo
  • Stuck Android Logo - YouTube www.youtube.com/watch?v=w6tmETIerBM
    • BY KELLER KING
    • 5 MIN
    • 553K VIEWS
    • ADDED 2013-06-13
    Video embedded · This video will show you how to restore your Ekko Tablet T700 if it gets stuck on Android Logo. Este v?deo vai mostrar-lhe como restaurar o Ekko Tablet ...
  • Android Tablet Stuck at Boot Screen - Stack Exchange android.stackexchange.com/.../android-tablet-stuck-at-boot-screen Android Tablet Stuck at Boot Screen. ... Samsung Galaxy tab 3 made in Korea stuck at android logo. ... T98G tablet stuck on boot screen.
  • Dec 29, 2015 | Tablets & eReaders
    My WiFi is has been turned off on my iview 756 tpc and too many unlock options were used by my and now it is going pass the option of asking for the gmail address and password. Seeing that the WiFi is off...
    if your tab launcher is locked only option is hard reset
    turn off your device
    hold vol up button and keep pressing power button
    it ll ask for factory reset push yes
    Feb 01, 2014 | Iview 7" Android 4.0 Tablet PC Model:...
    How to reset the iview tablet please?
    You will need to do a factory reset:
    1. With the device off, press and hold Volume Up and Power.
    2. Release the Power button when you see the Samsung logo, but continue to hold Volume Up until the recovery screen appears.
    3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
    4. Press Volume Up continue.
    Oct 31, 2013 | Iview 900TPC Tablet PC
    Pattern unlock android
    do a factory reset most of the time this works it take it back to the orignal state when you bought it
    it should up load all the needed files to restart it with out ant troubles
    Aug 23, 2013 | Iview Cyberpad 756TPC Tablet
    How can i fix the broken touch screen of my iview754tpc?
    Ebay has replacement touchscreens available for a reasonable price.
    Apr 04, 2013 | Iview 900TPC 9" Tablet
    Tablet freezes on boot up at android screen
    Do a factory reset. Turn the tablet off. Wait 10 seconds or so. Hold down volume down button while pressing the on button. Keep holding down both buttons until you see an android icon. It may be laying on its back with a red exclamation mark over it, like I saw. Once you see the icon, let go of the buttons and press the "back" or return button. This should bring up a list of options. You can scoll through the list by using the up or down volume buttons. I picked the option to delete all user data, which basically will set the tablet back to factory settings, like when you first got the tablet. Once that is complete, reboot the tablet.
    Mar 24, 2013 | Iview 760TPC Android Tablet, ARM Cortex-A8...
    Tablets & eReaders Logo
    97 people viewed this question
    Top Iview Tablets & eReaders Experts
    Hjalmer Lamminen
    Hjalmer Lamminen
    Are you an Iview Tablet and eReader Expert? Answer questions, earn points and help others
