Question about De Dietrich 23 in. DVF110J Built-in Dishwasher
My door has become very heavy after i heard a loud noise
Can I order a part and fix it myself
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Hi, my refrigerator door squeals very loud when you open it. The freezer side door does not make noise. I think it might be a washer at the bottom of the door, but I don't want to spray it with a...
You can try a silcone spray, that shouldnt damage any plastics or rubber. Also check the door seal. Make sure its clean. Sometimes, cordials, coke etc spill onto the door gasket and become all sticky which causes some wierd noises when you open the door.
Jul 26, 2011 | Admiral 26 cu. ft. Side-By-Side...
I heard a noise from my dishwasher. Next thing I knew, the door got really heavy - like a spring had broke. When you open the door now, it just falls - before it would stay up. Can I fix this myself or do...
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Aug 21, 2010 | Dishwashers
I have a GE Profile Harmony Dryer DPGT750. The machine makes a loud, almost grinding noise when the dryer is operating. It also sounds almost as though the drum is out of balance. It is more noticeable...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 26, 2010 | GE Profile Harmony DPGT750EC Electric...
2002 hyundai santa fe rear brakes creaking / scraping
change the brakes , the wheel bearings too should be ok
Jun 13, 2009 | 2002 Hyundai Santa Fe
Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Door open and closing problem
My dishwasher model DU3003XL0 has a similar problem. It happened yesterday. I had opened the door all the way, and then I heard a loud clunk sound. I suspect it is the spring mechanism in the door, and am ordering new springs, and hope to fix it myself.
Wish me luck.
Apr 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
GE Spacemaker washer/dryer
If you can get it apart, you should be able to fix it yourself. This is a tricky task though (I've seen customers spend hours just trying to change a belt, which you'll have to remove), so you may want to pay the money and have someone come out.
It is hard to say without hearing the noise for myself, but my best educated guess would be that the dryer drum bearing needs to be lubricated. You should lubricate it with white lithium grease, about 1.5 ounces of it.
In order to do this, you will have to take the dryer front off, remove the belt from underneath the drum and then remove the drum. You will see a bearing on the backside of the drum (looks like a post with a ball on it). You will see where that inserts on the back wall of the dryer. You should put the grease in the insertion point, then put the dryer back together again.
Mar 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
De Dietrich 23 in. DVF110J Built-in Dishwasher Logo
18 people viewed this question
Top De Dietrich Dishwashers Experts
richie46
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
