Question about Amana Washing Machines
Cold water valve not working
Amana Washer NTW4880YQ cold water valve not working. No cold water enters washer. Inlet is clear of debris, hose is connected, cold water turned on to washer.
  • Amana Master
  • 5,323 Answers
The selinoid has gone bad in ur valve
Posted on Apr 11, 2015
  • 43 Answers
SOURCE: RAT PROBLEMS
you need to reset the switch just blow down the pipe at the opposite end to the switch till it cick again if that doesent work check for air leaks spread washing up liquid on the whole pipe and look for bubbles check wiring also
Posted on Dec 02, 2008
SOURCE: Fisher/Paykel GWL10US washer. Blinking hot and
When they say replace the valve There,s a very good chance the diaphram is the valve is purferated or split (common Problem).But you can Remove the coil from this & with pointy nose plyers you can unscrew the top & inspect the diaphram If it,s ok give us a bit more info Hope this helps.Cheers.
Posted on Aug 10, 2009
  • 713 Answers
SOURCE: no/low water inlet. Diag mode both ht & cold lights flash
first test water valve ohms reading, this fault could be either control module or water valve.first open top panel to see valves. turn power off to unit. try putting the hot water valve wire to the cold and the cold to the hot. hopefully they will reach, sometimes they dont. then put panel back on with loose screws. turn power on , select low water ,and hot fill.push start button but make sure your hoses r connected and turned on. the reason i"m telling u how to do this is to eliminate the control board as being faulty if the cold water comes into unit then the problem is your computer, if no water comes in it is your water valve.i hope this helps if u still need help please reply
Posted on Apr 20, 2010
  • 2183 Answers
SOURCE: Frigidaire FTF2140FS front load washer.
shut off the water valve,disconnect the hot water hose from the back of the washer,then turn on the water valve to make sure it's not the house water valve first before you start messing with the washer,if the hot water is working correctly then you could have a bad water valve on the washer.let me know what you find
Posted on Nov 19, 2010
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Washer LSQ9010PWS will not fill with
You need one of these partimage.aspx?imgid=z3bqljbfbxnfnjqzotc5my9mufcvc290b2hwdhjhcc8%3d
Posted on Jan 17, 2011
Kenmore eco cycle front load washer. error E70 displays and stops washer. What does E70 mean?
You should check the model number of the washer. If the model number starts 417, then the washer was made by Frigidaire. In that case, the E70 error indicates that cold water is not being detected at the washer inlet sensor.
In some cases, this could be due to connecting the hot water line to the cold water inlet (and the cold water to the hot water inlet). Make sure that the cold water shut-off valve is open. Try swapping the water hoses (close the shut-off valves first). Try new hoses; some anti-flood hoses will restrict the water flow if they detect damage. Thus you won't have sufficient water coming into the washer. (You can check this yourself. Turn off the shut-off valves. Disconnect the hoses from the washer and put the ends into a bucket. Then open the shut-off valves and check the water flow.) While you have the hoses off, check for debris in the inlet filters.
If the hoses are fine, you probably have a problem with the washer's inlet valve or the reed switch that measures incoming water. The inlet valve should be replaced if you find that only hot water enters the washer.
I hope this helps. Please add a comment with the model number of your washer for more information. It will be on the inside of the door opening (probably at the top).
Sep 30, 2013 | Maytag EPIC MFW9700S Front Load Washer
Wfk2801 no water input for final rinse. Cold water input for main wash ok Also pre-wash not working Thanks Bary Wiggins
you mean the rinse cycle is not starting or the water alone is flowing for rinse cycle?
Jul 13, 2008 | Bosch Washing Machines
Water continues to run into the washing machine through the whole wash cycle and even when the machine is off. I have to keep the tape turned off. other than that the washing machine functions normally.
Hi Welcome to FixYa I am Kelly. You have debris inside your water inlet valve. You can try to clean it by doing the following:
- First remove both hoses from the water inlet valve and remove the inlet screens of the water valve.
(Use a knife blade on the outer part of the screens to remove them from the water valve)
- Connect both hoses to the water inlet valve without the inlet screens.
- Connect ONE hose to the wall faucet
- Place ONE hose in a bucket
SELECT WARM WASH and start wash fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your trying to free the debris from the inlet water valve diaphram)
Stop Fill
Reverse Hose connection at the wall.... i.e. hook up other hose and disconnect the one you had connected. Place the hose you disconnected from the wall into the bucket.
START warm fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your STILL trying to free the debris from the inlet water valve diaphrams)
STOP FILL
- Connect hose to wall connection
- WASH the inlet screens under slowly running water until both sides are clean
- Remove hoses from the water inlet valve and install the inlet screens.
- Reconnect hoses and turn on water supply
TEST HOT and COLD fill
Turn off machine.... IF the debris was freed the water flow will stop when the machine is turned off.
If this flushing attempt does not correct your constant water flow the remedy is to replace the water inlet valve on your washer.
I can help with locating parts ON-Line but will need your model number to help you should you require a water valve.
Hopefully you are able to clear the debris by doing the above. (50 - 50 chance of it working)
Thanks for Choosing FixYa,
Kelly
Dec 17, 2010 | Washing Machines
Cold water tricles in . no normal flow does the washer valve need to be replaced
There are debri screens in many styles of washer fill hoses that can block up. And the end that connects to the back of your machine also has a reachable screen filter up inside the water valve inlet that can also block up.
Disconnect the water fill hose at the machine and check screens ... clean or replace if needed.
The screen are usually attached to the hose washer and will pop out manually with a small screwdriver or knife. Then turn the water valve on with the free end of the hose aimed into your washer tub to make sure you have free water flow from the faucet to the water valve. If all screens are clean and clear but still no water pressure going into the washer after reconnecting your hoses then you can suspect the water valve inlet assembly.
Dec 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
LG washing machine intellowasher 7 kg wd-8050f showing no inlet frequently even after cleaning the inlet connection point
Please unplug or shut off the power at the fuse box...
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valve The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.There are two wires connected to each solenoid (aka coil) on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Jan 19, 2010 | Washing Machines
My amana washer puts water in very slowly how can i fix this
Hi. Make sure that the feed faucets that are mounted on the wall are completely open, all the way. Check the filter screens in the hot, and cold hoses for debris, also. If all is well in these locations, this will lead to a failing inlet water valve assembly. Follow the procedure below.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first. Your symptoms indicate that the valves are not opening all the way.
Dec 07, 2009 | Amana Washing Machines
Problem with ge washer machine model wdsr2080d2ww will not fill''
HI. First you will need to check the water fill faucets to make sure that they are turned all the way on.If the faucets are on, then move on to the hoses. Check the hoses for kinks. Make sure the hoses are straight, and not curved. If all checks out Ok here, i would advise to move on to the filter screens.
The hot and cold water from your home is connect to the water inlet valve on the back of the washer. In each end of the water supply hoses there may be a filter screen to catch debris and prevent it from damaging the washer. The water inlet valve also has filter screens. If the filter screens become clogged, the result is low water pressure, no water or the wrong water temperature,as well. The water inlet valve can be identified by the water hoses connecting to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting adequate water pressure and to clear any debris from the line.
Inspect the filter screens on both of the hoses and the inlet valve for debris build up. If you find any debris, clean it out. The screens in the inlet valve are not removable so use caution to avoid damaging them.
If you are getting good water pressure and you find no build up of debris, then the inlet valve itself may be faulty.
TESTING PROCEDURE FOR THE WATER VALVE ASSEMBLY
NOTE:-(The water inlet valve can be identified by the water hoses connected to it at the back of the washer.)
(((If the inlet is operational, and passes the inspection and test, the culprit will be the timer.)))
Nov 02, 2009 | GE Washing Machines
My washer is not filling with water in order to begin the washing process
Oct 23, 2009 | Whirlpool Washing Machines
Cold water enters washer very slowly
First - check the water inlet hose screen for calcium or rust build-up.
If cold water is filling slowly, take these steps:
  1. Unplug the washer.
  2. Turn off the cold water supply faucet.
  3. Remove the fill hose connected to the back of the washer.
  4. Checkthe fill screen on the cold water inlet valve for debris or depositsthat can restrict the water flow. If necessary, you can carefully pullthe screen out and clean it. Flush the inlet thoroughly and replace thescreen. NOTE: If debris makes it past this screen, it can cause thevalve to leak and cause a flood in your laundry room. Monitor thewasher for this type of problem is you pull the screen out and clean it.
  5. Placethe end of the hose in a bucket and briefly turn on the faucet to checkfor proper pressure and flow from the cold water hose. If waterpressure from the cold inlet water hose is bad, check the hose forclogs. If the hose is okay, then I recommend calling a plumber to checkthe water supply to your washer cold water faucet.
  6. If the above checks do not help you resolve the fill problem, you will likely need to replace the inlet fill valve.
Your cold water fill valve (mixer valve) solenoid has failed if after cleaning - the condition remains.
CLICK HERE for a replacement part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 24, 2009 | Roper RAS8445KQ Top Load Washer
Amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Dec 04, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
