Question about KitchenAid 24 in. KUDM25SH Built-in Dishwasher
Child lock lite flashes after holding energy saver dry for more than 4 seconds
How do I turn off the flashing child lock lite ? I have already tried to press and hold the " energy saver dry " button, and the child lock lite is still flashing
5 Suggested Answers
SOURCE: Child lock blinks
Hold the Energy Sver buttoer for 10 seconds. That worked for me.
Posted on Aug 27, 2007
SOURCE: Child Lock continuously flashing
I got the same problem that started 2 days ago. Holding the Energy Saver Button for the 4 seconds does nothing. The dishwasher does not operate and the light flashes continuously when the door is closed. If I press the cancel button, both the Child Lock and Cancel button lights flash in unison. Did anyone find a solution to this problem?
Posted on Feb 15, 2008
SOURCE: Child Lock on or Flashing Energy Saver Dry
I suspect that the cycle "button" on the control panel is intermittent.  Try using a different cycle - If you always use "short wash", try the "normal" cycle.
This worked for me.  It will be too expensive to repair, so I am dishwasher shopping.
Posted on Mar 01, 2009
erpaalai
  • 999 Answers
SOURCE: kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Posted on Sep 03, 2009
No trabaja lo unico que tiene es una luz ensendida -chid lock
Pulse y mantenga pulsado
durante 4 segundos. SEGURO PARA NI?OS brilla.
Si pulsa cualquier tecla, mientras que su lavavajillas est? bloqueado, el
la luz parpadea 3 veces.
Para desactivar el bloqueo para ni?os
Presione y mantenga AHORRO DE ENERG?A EN SECO durante 4 segundos. El
la luz se apaga.
for those of us in English... the child lock is on...
Press and hold
for 4 seconds. CHILD LOCK glows.
If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off the Child Lock
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Sep 02, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
KitchenAid dishwasher KUDS25SH - Can't operate because child lock
If holding the "Energy Saver/Dry" button does not solve the control board problem then most probably the control board would have failed and needs to be replaced .
To identify it we need technical expertise in handling the circuit boards and knowledge on usage of multimeter is must.
Apr 05, 2010 | KitchenAid Dishwashers
The child lock is stuck on my kitchenaid superba dishwasher
Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Apr 03, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
Mar 02, 2010 | KitchenAid Dishwashers
How to unlock the child lock
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $86 for your model, plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
Feb 08, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid KUDS25SH
Sep 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Child lock shut off
Hold the button with the lock until the light turns off. Consult the manual.
Can you provide a model number?
Feb 18, 2009 | Dishwashers
Dec 30, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Child Lock light flashes continuously
allaroni No doubt the problem with your dish washer is bad key pad due to stuck button(s). The user interface you found in the technical data does not exist and what Whirlpool meant under this name only Whirlpool knows. They do not sell the key pad separate and that?s why you have to buy the complete console. Wherever you found the new part if it cost more then $150, let me know and I can get a better deal for you. Gendos post back....
Jun 27, 2007 | KitchenAid 24 in. KUDS25 Built-in...
the solution is to change the electronic control.....cost 110$
Sep 02, 2006 | KitchenAid 24 in. KUDS25SH Built-in...
KitchenAid 24 in. KUDM25SH Built-in Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
