Question about Samsung LE Televison & Video
Samsung le46b530p tv picture flickering
The back light is going on and off like a strobe
dave1645
  • 834 Answers
SOURCE: have a 40 inch samsung lcd tv, the screen flashes
you either have a bad bulb or a losse bulb in the lcd panel a good reapir shop[ can fix that by reseating the bulb or replaceing them
Posted on Nov 20, 2009
  • 1039 Answers
SOURCE: FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Posted on Mar 25, 2010
alpug
  • 1961 Answers
SOURCE: my vizio gv42l fhdtv 10a picture flickers like a
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Posted on Jun 03, 2010
Testimonial: "Thanks again. :)"
lovejoy91
  • 691 Answers
SOURCE: Picture and Sound flickers like
bad filters in the powersupply area
Posted on Nov 30, 2010
SOURCE: my tv keeps flickering like a strobe light, how do
Hi,connect the tv to a stablizer..dont connect it direct from power source and make sure you place it in a place where enough air can reach it.
Posted on Jul 31, 2011
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
Samsung tv model LNS3241DX flickers
I'm not sure of a jumper wire to cut, but one of the first things is to clean out the dust that has accumulated on the electronics. You can blow out the back with compressed air or disassemble the TV case and dust it. Sometimes a layer of dust can cause excessive heat to build and shut off any type of overload circuit. Good luck!
Dec 18, 2013 | Samsung Flat Panel 32-inch 720p 60hz...
Screen flickers
"once in a while" suggests its not going to be found until it gets more frequent. A number of possible reasons for this as it is a bit vague.
Sep 01, 2012 | Samsung LN55B650 55 in. LCD HDTV
Mar 25, 2010 | Televison & Video
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
What the heck is wrong with my tv??!?!
It looks like the power supply is giving up on your TV. The strobing is because the TV may not be getting enough power or is not being filter properly.
How old is the TV?
Feb 24, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
88 people viewed this question
Jerry Greenberg
Jerry Greenberg
