Question about Kenmore Refrigerators
795 713 How to replace Door part #4930JJ2028B
Need a guide on how to handle of the door
  1. How it's done:
    1. Remove the door panel to gain access.
    2. Remove and replace the broken door handle.
    3. Inspect door latch and replace if not working.
    4. Check door for proper operation.
    5. Reinstall door panel.
Door Handle or Door Latch Replacement Service Cost YourMechanic
Mar 20, 2015 | Cars & Trucks
Tip
Samsung dryer error codes
Samsung Dryer Fault Codes
ts Thermistor shortCheck for restricted vent. Replace thermistortoThermistor openCheck for restricted vent Replace Thermistor
do Door OpenCheck connections. Replace door switch.
FE Power Source Frequency errorCheck power source
dF Door circuit failureCheck wiring to door switch. Replace door switch
hE Heater errorRestricted vent. Replace thermistor.
bE Button ErrorCheck and / or replace PCB
od Over drySensor Bar open. Adjust time up excessively.
Et eeprom failureReplace Eeprom
on Apr 14, 2015 | Dryers
Lg p/no 3850dd3006a leaks at door
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a sheet of paper and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced
Jun 19, 2014 | LG Dishwashers
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 26, 2013 | Sanyo Microwave Ovens
Door wont shut
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Miele Dishwashers
Skin Replacement vs Door Replacement
You can easily get a complete door from an auto wrecker that will be far better than a reskinned door. I didn't think they even did that anymore. You may even be able to get one the same as your existing color so that you wouldn't even have to worry about paint fade differences. Most auto wreckers are on a network and they can put your request out to the whole area and likely come up with one. If the used door route is not an option, then "new" is the only way I would go.
Apr 05, 2009 | 2005 Honda Civic
Hotpoint aquarius 1000wm 20 I have to bash front door to start
I do not think it is the door lock that is faulty, more likely to be a weak or broken door spring or broken door catch.
I would replace these first,and then if it is still the same, then replace the door lock.
To replace the spring and or handle catch, undo all the screws that secure the 2 halves of the door, and prize apart the 2 halves,
Replace the spring and catch, reassemble the door.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How to find and replace a freeezer door seal
on many models, it is not possible to fit a replace,ent door seal - they are foamed into the door and to replace the seal means replacing the whole door
Aug 27, 2008 | Freezers
Refrigerators Logo
13 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
