Question about Ryobi Garden
PUMP NOT DELIVERING OIL TO CHAIN
PRESS PUMP NOT DELIVERING OIL TO CHAIN
  • negars Jun 23, 2009
Stihl chain saw 024 AV , chain does not get oil
run it with the bar off and see if it pumps oil. I have drained oil tank and cleaned with gas(no run) then replaced with lite oil , run no chain and got them going ,or then gingerly run wire into oil hole and got them going, otherwise its tear apart time. If oil does come out, then clean your bar and your cover and use bar chain oil.
Mar 01, 2015 | Stihl 024av
Chain turns when idling
If the oil pump gear is driven by the back of the sprocket you must make sure the the sprocket has engaged into it correctly if it has not the sprocket will bind on the back of the clutch
Sep 07, 2012 | Garden
Husquavarna 455 chain oil problem
is the tin plate on the right way?(not blocking the hole)did you change the bar and the replacement blocking the oiling hole
Aug 19, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Replacing Oil pump in Ford Expedition
the oil pump is on the crank behind the balancer and timing chain cover:
REMOVAL
1. Remove the timing chain.
2. Remove the oil pan.
3. Remove the three (A) oil pump screen and cover bolts and the (B) oil pump screen and cover.
4. Remove the two oil pump bolts and the oil pump.
INSTALLATION
1. Clean and inspect the mating surfaces.
2. Install the oil pump and loosely install the two oil pump bolts.
3. Install the oil pump screen and cover and install the three oil pump screen and cover bolts.
4. Install the timing chains.
5. Install the oil pan.
Apr 25, 2012 | 2003 Ford Expedition
Husky Rancher 455 is not delivering enough oil to the bar...ports are clean, bar is clean and oil is coming through port on the saw. Brand new chain is now dirty after one tank full. Leak somewhere?...
a few of things here, the pick up pipe can get kinked thus slowing the oil flow down, the filter on the end of the pick up pipe may be partly blocked,if you are using non fling oil and the outside temperature is very cold you may need to thin the oil to allow a better flow, finally you can modify the pump shaft, this is done by increasing the angle on the end of the pump piston ( the bigger the angle the bigger the throw of the shaft and the more oil is pumped ) this is a final resort and has to be done with care, you have to remove the shaft from the pump body and hold against a grind stone to increase the angle
Jan 06, 2018 | Husqvarna , No.455 Rancher, 20" Gas -...
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 | Garden
I have a Husqvarna 455 rancher that has stopped delivering bar chain oil. I have cleaned, replaced the bar and experimented with different weight oils but still no luck. I keep waste oil in old bar chain...
Most 455s have a three position oil pump, the adjuster is a slot head screw acessed through the bottom of the crankcase, try increasing the flow first, if no better, you need to remove the clutch and sprocket to gain acess to the pump, the oil pump drive gear is nylon and driven by the sprocket, check this is in good condition, behind the pump is a pick up pipe that pushes into the tank via a moulded grommet in the pipe , gently lever this out of the tank,on the end is a filter. if you are brave enough you can increase the throw of the pump shaft by grinding a steeper angle on it, but this is a skilled job and a last resort, i have had to do a few where they are running longer guide bars and need more oil, let me know if you need more help.
Jun 04, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do i change the oil pump in a 2000 dodge intrepid
I'm assuming that you are talking about 2.7L, the check this procedure...
Removal & Installation - 2.7L Engines
  1. Drain the engine oil.
  2. Remove or disconnect the following:
    Crankshaft damper Timing chain cover Timing chain Crankshaft sprocket Oil pan Oil pickup tube and O-RING Oil pump
To install:
Fig. Oil pump mounting bolt locations-2.7L engine
  1. Fill the oil pump rotor cavity with clean engine oil.
  2. Carefully, install the oil pump over the crankshaft and into position.
  3. Install the oil pump mounting bolts and torque to 21 ft. lbs. (28 Nm).
  4. Lubricate the new pickup tube O-ring with clean engine oil and torque the pickup tube mounting bolts to 21 ft. lbs. (28 Nm).
  5. Install or connect the following:
    Oil pan Crankshaft sprocket Timing chain Timing chain cover Crankshaft damper
  6. Fill the engine with clean engine oil.
  7. Start the vehicle, check for leaks and repair if necessary.
Hope helps (remember to rate this).
Oct 02, 2010 | 1999 Dodge Intrepid
How to change oil pump in 4.7
Here you go:
1. Remove the oil pan and pick-up tube.
2. Remove the timing chain cover.
3. Remove timing chain and tensioners.
4. Remove the four (4) bolts, timing chain tensioner and oil pump.
5. Position the oil pump on the crankshaft and install two (2) mounting bolts.
6. Position the primary timing chain tensioner and install the two (2) remaining bolts.
7. Tighten the pump and tensioner retaining bolts to 21 ft lbs in the sequence shown in attached photo.
8. Install the secondary timing chain tensioners, chains, cover, pick-up tube, and oil pan with new gasket.
See the photo below. Hope this helped and best wishes.
Jul 31, 2009 | 2000 Dodge Durango
Oil pump replacement
This MAY seem Strange But It IS ALL necessary for Oil Pump Replacement. And Please Don't Forget to Rate Me as Most Folks Do Not. Thank You and GOOD LUCK with the Oil Pump Job Also
OIL PUMP
It is necessary to remove the oil pan, oil pickup and chain case cover to service the oil pump rotors. The oil pump pressure relief valve can be serviced by removing the oil pan and oil pickup tube. Refer to Timing Chain Cover Removal and Installation for procedures.
DISASSEMBLY
  1. To remove the relief valve, proceed as follows:
  2. Drill a 3.175 mm (1/8 inch) hole into the relief valve retainer cap and insert a self-threading sheet metal screw into cap.
  1. Clamp screw into a vise and while supporting chain case cover, remove cap by tapping chain case cover using a soft hammer. Discard retainer cap and remove spring and relief valve.
  2. Remove oil pump cover screws, and lift off cover.
  3. Remove pump rotors.
  1. Wash all parts in a suitable solvent and inspect carefully for damage or wear.
Oil Pump Assembly
  1. Assemble pump, using new parts as required. Install the inner rotor with chamfer facing the cast iron oil pump cover.
  2. Tighten cover screws to 12 Nm (105 inch lbs.).
  3. Prime oil pump before installation by filling rotor cavity with engine oil.
  4. Install chain case cover. Refer to Timing Chain Cover Installation.
REMOVAL of Timing cover
REMOVAL
  1. Disconnect negative cable from battery.
  2. Remove timing chain cover.
REMOVAL Of Oil Pan to gain Access to OIL PUMP
  1. Disconnect negative cable from battery and remove engine oil dipstick.
  2. Raise vehicle on hoist and drain engine oil.
  3. Remove bending brace to transaxle attaching bolt.
  4. Remove bolts attaching dust cover to transaxle housing. Lower dust cover to gain access to oil pan bolts.
  5. Remove oil pan screws and remove oil pan.
INSTALLATION
  1. Clean surfaces and apply a 1/8 inch bead of Mopar (R) Silicone Rubber Adhesive Sealant or equivalent, at the parting line of the chain case cover and the rear seal retainer.
    1. Use a new pan gasket.
    2. Install pan and tighten screws to 12 Nm (105 inch lbs.).
    3. Install dust shield and bending brace to transaxle housing.
    4. Lower vehicle and install oil dipstick.
    5. Connect negative cable to battery.
    6. Fill crankcase with oil to proper level.
Mar 27, 2009 | 1998 Chrysler Town & Country
Garden Logo
44 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
