Question about 1997-2004 DODGE DAKOTA CHROME GRILL GRILLE KIT 1998 1999 2000 2001 2002 2003 97 98 99 00 01 02 03 04 SPORT SLT R/T CLUB CAB 4X4 PLUS SXT EXT CREW
Clutch system diagram
Clutch
  • 312 MOTORING Master
  • 2,210 Answers
More info needed?
Posted on Jul 30, 2014
Need a clutch pedal diagram for a 1999 s10 2.2 4cyl manual trans
Sorry no diagram. But here is how it works. In the start position(Power) the wire goes to the start fuse, from the fuse it goes to the clutch pedal switch. Push the pedal and it goes to the starter relay. On the other end is ground. If it is good it pulls the relay closed. On the closed end is battery power to the starter.
Mar 09, 2016 | 1999 Chevrolet Silverado 1500
Need Diagram of linkage for 2002 PT Cruiser under the hood
There is no "linkage" under the hood. It is a hydraulic clutch, and the only linkage is form the pedal to the clutch master cylinder, which is bolted directly to the firewall. So all the physical "linkage" is inside the passenger compartment.
Here is a picture of the master cylinder:
You can see the bolts that come thru the firewall..
If you are having issues with the clutch, I recommend replacement like the dealer recommends: the complete sealed system. You can get it at Autozone via special order. It comes completely assembled, including Master and Slave cylinders and reservoir. Here is a picture of that:
Nov 04, 2015 | 2002 Chrysler PT Cruiser
How do i troubleshoot my clutch system
No, the clutch and brake hydraulic systems are not connected.
If you are loosing fluid, you should be able to tell if it is leaking from the master cylinder where you add fluid, or the slave cylinder on the transmission.
Jun 18, 2015 | 1999 Ford Escort
Is there a diagram of where the clutch return spring is on a 2008 Hyundia Santa Fe?
The clutch don't have spring to return. hydraulic pressure return the pedal. if you pedal go down to the flour and don't return you lost the pressure. First look in the reservoir for fluid. add DOT3 brake fluid and bleed the system. inspect for leak
Good luck
Apr 15, 2014 | 2007 Hyundai Santa Fe Limited
I need a diagram of the primary chain and clutch
Not much of a diagram as the chain merely runs around the compensator, over a chain adjustment device and around the clutch basket sprocket and back to the compensator.
Apr 15, 2014 | Harley Davidson FLSTC Heritage Softail...
I need wiring diagram for1997 Lincoln towncar AC showing ac clutch circut, Clutch will not come in. System has charge, clutch is ok and system puts out cold air when clutch is jumped to battery.
ok near the fire wall you have your dryer on the dryer is a two wire switch for your low pressure. Jump that wire if your compressor comes on then the switch is bad. this is a common problem on these cars
May 10, 2011 | Ford Lincoln Continental Cars & Trucks
1995 Chevy Cavalier Fluid leaking somewhere from hydro clutch line..need diagram that shows the system. There is a small container that is labeled Clutch that was empty.
There are only three parts to the system...the "container" that is the clutch master cylinder, a line between that and the clutch slave cylinder (which is the third part). It works same as your brakes ...step on the clutch and pressure from the master flows through the line to the slave. The slave moves the fork that pushes the clutch in to disengage it. Just like your brakes, any leak in any component will cause it not to work. Re-fill the master and have someone work the clutch and watch for leaks. Also inspect the area under the dash where the pedal rod goes through the firewall. if it's damp there the master is bad. After replacing whatever failed, you need to bleed the air from the system (should be a valve on the slave)
Sep 20, 2009 | 1995 Chevrolet Cavalier
Yz 125 1990 clutch spring diagram
www.bikebandit.com
It's one of the few that has a diagram.
Not sure what you mean by anti-rattle? The springs are for the pressure plate, and allow the clutch to grab, so you can go.
Sep 13, 2009 | Yamaha YZ 125 Motorcycles
Clutch not disengaging
Hydaulic clutches are much like a brake system. There is a master on the firewall and a slave either in the bell housing or on it. If the pedal feels normal, the clutch is probably messed up.
Word of advice. If you change the clutch, replace the slave if it is internal. It can be worth it! Bleed the system much like you do brakes.
Mar 30, 2009 | 2002 Chevrolet Cavalier Coupe
2004 Dodge 2500 Diesel Not Starting
should be a switch on the clutch pedal check and see if it is still plugged in
Sep 23, 2008 | 2004 Dodge Ram 2500
1997-2004 DODGE DAKOTA CHROME GRILL GRILLE KIT 1998 1999 2000 2001 2002 2003 97 98 99 00 01 02 03 04 SPORT SLT R/T CLUB CAB 4X4 PLUS SXT EXT CREW Logo
105 people viewed this question
Top 312 MOTORING Vehicle Parts & Accessories Experts
ray gallant
Renee Knafel-Bullock
Paula Hamilton
Are you a 312 MOTORING Vehicle Part and Accessory Expert? Answer questions, earn points and help others
