Question about Comet BXD2527 Pressure Washer Pump
Troy bilt pressure washer 020207 won't draw soap
    Top Expert:
  • 14,161 Answers
Below is a list of the MOST COMMONLY reported troubleshooting issues.
you might want to try these steps:
No detergent
Reservoir is empty
Add more detergent
No detergent
Detergent suction tube not properly connected to the machine
Check connection
No detergent
Detergent is too thick Dilute detergent
No detergent
Filter on detergent suction tube is closed
Open the filter by turning it to the desired detergent intake
No detergent
Filter on detergent suction tube is clogged
Run warm water through filter to remove debris
No detergent
Damaged or clogged detergent suction tube
Remove obstruction or replace detergent suction tube
No detergent
Spray wand is in high pressure position
Turn spray wand tip to low pressure position
No detergent
Discharge nozzle is obstructed Blow out or remove debris with a fine needle
reference from:
http://troybilt.custhelp.com/app/answers/detail/a_id/10652/~/basic-troubleshooting---pressure-washers-%28gasoline-powered%29
please consult the operators manual you can get from link below:
Parts Manual Finder
or a Professional Shop Manual for model specific technical information.
If professional service is needed, please utilize the Authorized Service Center Directory to have the equipment professionally inspected and serviced.
You may also contact our Customer Technical Support department at:
Toll-Free Sales and Support (U.S.A. Only) 800.828.5500
Hours of Operation (EST)
Monday-Friday: 8:00am - 8:00pm
Saturdays: 9:00am - 8:00pm
Sundays: 10:00am-6:00pm
Posted on Jun 30, 2015
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy bilt pressure washer not siphoning soap
clean and soak all valves if do get work do not leave solution in it over time.carb cleaner with that little straw
Oct 19, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Need instructions on the use of the soap dispenser on a 2700 psi B&S power sprayer
Dear Audience,
Please go to the link provided and view the on line PDF manual. On pages 16 and 17 you will find the directive to apply detergent into the system and maintaining successfully.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/020292%20man.pdf .
If you are having any difficulty , please check out this direct source Troy bilt Pressure Washer Support ManualsOnline com .
Fare. Well.
Sep 24, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Have a troy bilt 220 lb Briggs Stratton Put the clear tube into the gallon of soap, but will not draw. Also, how do I remove the nozzle to attach the low pressure nozzle to apply soap solution?
It won't draw soap unless you have the low pressure nozzle on. It can be replaced by pulling back on the slip collar then pulling out the nozzle. The new nozzle is then put in by again pulling back the slip collar and sliding the new nozzle in, making sure the collar goes all the way back and locks into place.
Jun 19, 2011 | Garden
Pressure Washer Troy Bilt 2700 PSI 2.3 GPM will not pick up soap. I am using the black tip low pressure head and it still does not pick up the detergent. Any recommendations?
Take the small soap line off and make sure you can blow air through. Where the line attaches to the soap container make sure the hole is clear if not take a streight pin and make sure the pin goes in the hole easily.
Mar 14, 2011 | Garden
Soap will not siphon on my Troy Bilt pressure washer.
Are you using the soap on low pressure. This is the only way it will work
Sep 19, 2009 | Garden
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Troy bilt pressure washer 2200 psi
inlet valve connected to water inlet is stopped-up. Unscrew it, take a safety pin run through valve then take the pin and push through valve connected to pump. should do the trick. (the valve the suction hose for the soap is connect to)
Mar 31, 2008 | Washing Machines
Comet BXD2527 Pressure Washer Pump Logo
211 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
