Hi my Bosch Logixx 8 Varioperfect has Error code F67 flashing. How do i solve this
2 Suggested Answers
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
Hi. Have a Bosch Loggix 8 VarioPerfect WAS32440AU. It has been displaying a uPd code. Was hoping that you can verify the issue. TIA Brian.
First, of all it is a Bosch "Logixx".
Not a whisper of your fault code anywhere... go to this site and towards the bottom you will see a FORM to ask directly about your specific model AND your exotic fault code! Are you sure you have that "code" right?
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes
Then I found THIS bad news!
"There are a number of different version of the electronics used in Bosch Group made washing machines and washer dryers that are sold as Bosch, Siemens and Neff and most of them use the different fault or error codes when they have a problem or a spare part fails. This particular article relates especially to the range of Logixx washing machines that have an ENR number in the format of WAS****GB/** where the asterisks replaced by a number for each one."
Find a long list of fault codes here:
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Yours is not on the list? Still sure about that number?
Anthony
Apr 02, 2018 | Bosch Washing Machines
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Drain error detected
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Washing Machines
Bosch logixx 8 varioperfect
you will have a broken spider in the machine
Jul 22, 2014 | Washing Machines
Bosch logix8 comming up with the code nro
Bosch Logixx 8 error code nr0 means - The childproof lock has been activated.
Just deactivate the childproof lock.
Apr 10, 2012 | Bosch Logixx WFT 2806 Front Load...
My Logixx 8 washing machine is stuck at error code F:23. What is that waiting for ?
Unfortunately it is waiting for an engineer to investigate 'flooded base s/w activated' which is what the Bosch Logixx F23 stands for ;-0(
Sorry.
John C
Mar 19, 2011 | Washing Machines
I have a bosch logixx 8 washing machine. Fault code f67 when I turn the machine on. What does this mean?
I have Logixx8 WAS 32782 that got the f-67 code. I had it repaired today and the technichan updated the software. f-67 was indicating "lost contact with display panel". The display panel had of some reason erased its software. SW update was the standard solution.
Oct 02, 2010 | Bosch Washing Machines
Washing Machines Logo
Top Washing Machines Experts
