Question about PfaFF Sewing Machines
How do you stop a sequence stitch on a pfaff expression 2.0
When you stitch one of the decorative stitches , what button do you push so that the machine stops at the end of the next completed stitch
    Sergeant:
  • 249 Answers
Press the decorative (sequencing) button again to cancel and the sequence will complete.
Posted on Apr 13, 2015
SOURCE: Pfaff Hobby 1142 Reverse stitch lever twisted doesn't work
I have the same problem. |Until I can get it fixed \i have been tipping it back to straight and then pressing down evenly which seems to give me a little reverse. I think that the plastic extension inside is cracked. \i hope that this is a part that is acessible!
Posted on Jan 10, 2009
kent581
  • 87 Answers
SOURCE: Husqvarna Prisma 980 decorative stitch cassettes don't work
On that machine, the cassettes aren't actually computer chips. Each cassette has a little spot of white on a certain little area you must find (top right I'm pretty sure). Look in the machine at that point. There is a sensor that looks for that white spot, and as it identifies it, it changes stitches according to that cassette. Either the sensor is blocked, gone bad, or you can put a fresh coat of white paint on with white out. I hope this helps.
Kent
Posted on Mar 23, 2009
SOURCE: machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Posted on Apr 17, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
  • 10 Answers
SOURCE: PFAFF 362 Sewing Machine: The shift
Remove the top cover (grasp and lift straight up), spray with "Tri-Flow, liberally inside. Pay attention to the right 1/2 and behind the front dials.
In Front, each dial has a small square opening on the side, use the tube included with the "Tri-flow" to squirt lube inside them. DO NOT use WD-40.
Run the machine daily for 5-10 minutes (set the dial "C" [top front that goes up to 8] to 0 also set the dial on top of the case to 0. Move the Zig-Zag lever (upper right) from 0 to 4 and back again. Respray with Tri-flow. After a couple of days, if it is still stuck place a hair-dryer or light nearby to warm it up to skin temp.
Between the temp and the oil, it should begin working.
Break a Leg!
Posted on Jan 08, 2010
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
I need to know how to wind a bob in for Pfaff 2036 machine. I would also like to obtain a copy of the instruction manual for this machine
How about this?
Threading Pfaff Sewing Machine mov
PFAFF expression 2034 Instruction Manual
(this is for a 2034 but is probably close enough to your machine to be useful. Usually, there is a very slight different between models, that most often just entails a few extra features or decorative stitches.)
Nov 03, 2016 | PfaFF Sewing Machines
Pfaff 360, how do I stop the zig zag stitch on my machine?
could you explain more about what the machine zig zag stitch is doing or not doing?
Mar 13, 2016 | Sewing Machines
HOW TO DELETE SEQUENCES FROM MY PFAFF AMBITION 2.0 SEWING MACHINE? it is brand new
if the machine is still under warrenty, I would take it back. if you got a manual with the machine it should have a section in it for the deleting, if all else fails contact pfaff customer service and ask them what you can do, here is a link
Contact
Mar 06, 2016 | PfaFF Sewing Machines
The instructions on pg 40 of the manual says to hold the Delete button in for a longer period.
quilt ambition 2 0
http://sewing.patternreview.com/SewingDiscussions/topic/89785
Also found the following comment to a review:
Jo-Ann16 May 2013 at 07:30
"Hello, I have the ambition 1.5, absolutely love it. To switch the font to normal stitching you have to delete or save the sequence. To delete it just tap the little garbage photo and to save tap the heart. With that done you then go back to your stitching tab select a stitch and tap the little garbage bin to erase sequencing and go back to normal stitching."
How do I set the basting stitch length? when I try, it just beeps at me.
A BASTING STITCH IS ONLY A LONG STRAIGHT STITCH. THE NUMBER THAT IS LOWER IS A LONGER STITCH (FEWER STITCHES PER INCH). YOU WERE LIKELY MOVING YOUR NUMBER HIGHER. AFTER YOU GOT TO A CERTAIN NUMBER IT NO LONGER QUALIFIES AS A BASTING STITCH BUT A STRAIGHT STITCH. USE A LOWER NUMBER AND IT WILL LIKELY TO STOP THE BEEPING.
Sep 30, 2014 | PfaFF Sewing Machines
The decorative stitch mechanism on my pfaff 1222 does not work
since it's a pfaff, I suggest having the machine checked to
see if a part or gear has become damaged and needs to be replaced
or the stitch mechanism may need some type of adjustment.
Dec 14, 2012 | Sewing Machines
Message remove thread jam under the stitch plate keeps appearing! It's clean!
After cleaning out the bobbin area, re-threading the top thread, turning my Pfaff 4.2 off and on it still said " remove thread jam under the the stitch plate". I pushed the "ok" button and it started working again.
Keeping my fingers crossed.
Aug 13, 2012 | Pfaff Creative 4.0 Sewing Machnie
Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Feb 24, 2010 | Sewing Machines
Sewing Machines Logo
47 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
