Question about Garden
850 2 stroke toro push lawn mower. 1st season use won,t start
  • 109 Answers
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Posted on Apr 26, 2009
  • 86 Answers
SOURCE: I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
Posted on May 16, 2009
  • 81 Answers
SOURCE: billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Posted on Jun 19, 2009
  • 130 Answers
SOURCE: Toro lawn mower won't start with electric start.
need more information. on this so i can help you.ok let me know please
Posted on Jul 22, 2009
  • 17 Answers
SOURCE: Toro Lawn mower running rough/usually won't start/backfires
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
IN your problem it might also be for some reasons like the crankshaft is bent, that damages the motor internally and cannot be fixed, hppens on older mowers. and is caused by when you run over twigs and branches andything hard!
Posted on Aug 11, 2009
Lawn mower manuals
because it's a "push" mower... lol, get it... ok let's move on. Dirty air filter and/or spark plug, bad gas, dirty carb, no spark blown engine. operator presence handle not working correctly...
Sep 02, 2014 | Toro Lawn Mower With Toro Power Tools
Toro mower over heats
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jul 10, 2014 | Toro Lawn Mower With Toro Power Tools
Toro whirlwind push mower fuel mix
4 stroke engine, no fuel oil mix.
Aug 08, 2012 | Toro Power Lawn Mower
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
What oil to I use in toro self propelled lawn mover is 5w30 ok
Hi jonconbuck...
5W30 is ok during the winter season...but use 10W30 or 30 W non detergent during the summer season
Please take time to rate me
Sep 11, 2011 | Toro Power Lawn Mower
I have a toro lawn mower. For the last 3 seasons the carb get srcewed up. Usually early in the season. The mower just stalls, and then will not stay running. It seems like it just runs out of fuel. What...
If replacing the carb fixes the issue it is likely just dirty or bad fuel in the old one. make it a habit of running your mower out of fuel at the end of the season and ALWAYS use a fuel stabilizer in your outdoor power equipment fuel
May 26, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
Billows of white smoke when Toro lawn mower runs
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
