Question about KitchenAid Dishwashers
Remove end cap - KitchenAid Dishwashers
How do I remove the soda bottle cap, from the drive shaft end of a 2004 Saturn Vue V6 AWD, in order to remove the yoke, when replacing the carrier bearing.
Can you post a picture of this "bottle cap".. I think you are just seeing the splines (they can kinda resemble the rough crimpings' that a bottle cap has...
There should be nothing on top / on the end of the Midship splined stub shaft... You remove the hog-ring, and press the yoke off/over the spline. the spline and end yoke have a "dead spot" - which makes you keep the driveshaft in-phase during reassembly.. the dead spot is 2 splines that have been joined together at the end.. the end yoke will have a spline removed to accommodate this...
PS - soak the end yoke and spline liberally with PB Blaster.. Walk away..the longer the better... Then attempt to remove.. Good Luck!
Dec 01, 2016 | Saturn Cars & Trucks
Brush not turnning
The brush roller is driven by a belt installed on the motor shaft. The belt could be broken or off the shaft. The brush roller could be clogged inside the end caps with debris which prevents rotation. To solve the debris problem, it will be necessary to remove the belt from the motor shaft, then note the orientation of the end caps and remove the brush roller. Next, remove one end cap and check for clogging material. Remove the material. Slide the brush roller shaft away from the end of the brush roller to check for clogging material at the opposite end. Remove the material. Slide the brush roller shaft back into position and reinstall the end cap. Reinstall the brush roller in the correct position. Reinstall the belt. Check for proper rotation of the brush roller.
Apr 08, 2014 | Electrolux EL8905A Nimble Brushroll Clean...
Hayden supervac
There are end caps and you can replace them. You will need to expose the brush bar/ beater; and remove it. Dig out the end caps and replace with exactly the same type. If you inspect the so called bearings, you may find matted up material that caused the stoppage. Clean and retry the system before getting a set of end caps.
Apr 03, 2014 | Vacuums
Remove upper rack
When you pull the upper rack forward, the two metal glides on each side move forward. On the end of each glide is a white plastic end cap. If you look through the rack to the inside of each glide, you can see that the upper part of the end cap has a upper tab. I put my thumb on the end cap then press the upper tab forward with my index finger. Then press upward with your thumb and the end cap should slide totally upward and then out of the glide. Once both end caps are removed, the upper rack slides fully out of the washer.
Jan 25, 2014 | Whirlpool Gold 24 in. Built-In Dishwasher...
Faded print on the page, light on the right porgressively dark on the left.
I had this issue as well and parkerguy's transfer roller cleaning suggestion solved it! One point to mention though if you have the CM1312nfi MFP is that the transfer roller is attached to a cage on the back door of the printer. To remove the transfer roller, you do NOT need to remove the cage. Simply open the back door and locate the white plastic cap attached to the end of the transfer roller. You'll need to slightly pry up the white tab that extends down from that white cap in order to turn the cap clockwise to remove it. Once you've removed the white cap, follow the same process to remove the black cap from the other end. Once you have both the white and black caps off, simply slide the transfer roller toward the black cap end, ensuring to feed the pin through the hole so the pin at the white cap end comes out. Now the transfer roller is free and in-hand, ready for cleaning. Note that the transfer roller pins are shaped/sized differently to ensure the proper end is inserted into the proper hole, so you should note which end belongs on which side. To reinstall, simply reverse the process, sliding the appropriate transfer roller pin through the hole on the black cap end, then insert the other roller pin through the hole on the white cap end and reattach the caps, ensuring the tab on the cap is reseated properly. Close the back door and you should be in business!
Dec 10, 2012 | HP Color LaserJet CM1312nfi Laser Color...
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
How do I change the batteries in a AA maglite?
Remove the end cap by turning counter-clockwise and pulling cap off. It may be a pretty tight fit so you can wrap a rag around base cap and use pliers to loosen. Use rag or duct tape to protect finish on your light end cap. The threads are very fine so after you have removed end cap and replaced batteries be careful not to cross thread when reinstalling end cap. I hope this helps you. Thanks.
Dec 17, 2010 | MagLite Mag-Lite& Flashlight
Replace controller module Polyvision 1600
To replace the controller the end cap can be removed by removing 2 screws that are on the back of the board. The end caps will then slide off.
Feb 11, 2009 | Polyvision Walk-and-Talk Lightning WTL...
Changing the sm card in my side kick 1 How?
is it not on the shoulder the same as with the side kick2? check there there should be a spot where u can press down on the sim card and it will pop out
Jan 26, 2008 | T-Mobile Sidekick
Dishwashers Logo
14 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
