Question about Cell Phones
How to reset iphone without itunes - Cell Phones
  • 84 Answers
Go to Settings, general, and in about phone there is a master reset.
Posted on May 12, 2014
5 Suggested Answers
SOURCE: How to put music on your iphone without using itunes
I would also like to use the iPhone without iTunes.
iTunes is one of the worst programs i' ve ever tried. It´s slow, big and way to complex. It feels like a mac ( totally unnecessary..:-)
I tried it when i bought my iPod Shuffle. Luckily i found a little program, that could do the job without iTunes.
I want my computer to find the iPhone as an USB disk and just copy paste the music.
Posted on Jun 23, 2008
sknerdish
  • 53 Answers
SOURCE: iphone won't sync with itunes
your sad!!!!!!!!!!!!!!!!!
Posted on Feb 18, 2009
SOURCE: Hi there.. I have same problem here with my Iphone 3gs
my iphone dosent start normal when i press power botton its start on recovery mode only and if i try to recover and restore it but shows error "your iphone couldent be restored"
Posted on Nov 27, 2009
mobil master
  • 14641 Answers
SOURCE: how to reset password on iphone without itunes
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Sep 06, 2012
My iPhone 6 is dsabled. How do I get my phone back
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apr 04, 2017 | Apple iPhone 6
I need to reset my phone amd i forgot my passcode
Hello Karabo, what kind of phone do you have?
If you're an iPhone user and forget your passcode, you will have to factory reset it without Apple ID. To do this you need first put the phone into DFU mode and connect it to iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Restoring iPhone to factory settings with this method will result in wiping all the data. The following steps will show you how to do that.
1. Open iTunes on your computer and connect your iPhone to the computer with a USB cable.
2. After that, turn off you device. Press and hold the Home button for 3 seconds.
3. Put your iPhone into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPhone into DFU mode.
4. When iTunes detects that your iPhone is in recovery mode, you can restore it now.
5. Click on Restore iPhone. Then you will be notified after the reset and your iPhone will take a restart.
After factory resetting iPhone, you will get all the data swept from iPhone 6 Plus, and you can restore the files from your iPhone, iTunes backup or iCloud backup.
How to Restore iPhone 6 Plus to Factory Settings
Jan 19, 2017 | Cell Phones
I have iPhone 6&6s..form previous owners..how do I start when it asks for ID's and they can't remember
Generally speaking, you need the Apple ID to reset your iPhone. iPhone needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPhone, you need to enter the Apple ID when your iPhone reboots.
But if you have no Apple ID or passcode, you will have to reset your iPhone without Apple ID. To do this you need first put iPhone into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Resetting your iPhone with this method will result in wiping all the data in your iPhone.
Step 1: Open iTunes on your computer and connect your iPhone to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPhone into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPhone into DFU mode.
Step 4: When iTunes detects that your iPhone is in recovery mode, you can restore it now.
Step 5: Click on Restore iPhone. Then you will be notified after the reset and your iPhone will take a restart.
After resetting your iPhone with the guidance mentioned above, you'd better create a new Apple ID and password in time.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Dec 21, 2016 | Cell Phones
How to unlock my iPhone without factor reseting it please help
either remember code or can try notifying provider for assistance
Oct 22, 2016 | Cell Phones
Forgot password on my old iphone 4s 16gb
It's the most frustrating thing for us to forget our iPhone password. In order to unlock and access your iPhone normally, you need to reset your iPhone password. Resetting iPhone password is not complicated.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
  3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
  4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
forgot-password-old-iphone-4s-16gb-oxaxc0rwhkhzilrwacqreyis-1-0.jpg After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
How to Reset Password on iPhone
Oct 12, 2016 | Cell Phones
How do I reset my iphone
reset-iphone-oxaxc0rwhkhzilrwacqreyis-5-0.jpg But if you have no Apple ID or passcode, you will have to reset your iPhone without Apple ID. To reset iPhone without Apple ID, you need first put iPhone into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Resetting your iPhone with this method will result in wiping all the data in your iPhone. The following steps will show you how to do that.
After resetting your iPhone with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPhone, you will get all the data swept from iPhone, and you can restore the files from your iPhone, iTunes backup or iCloud backup. However, you can't backup iPhone to iTunes/iCloud without Apple ID before you reset your iPhone . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPhone after factory reset without Apple ID.
via How to Reset iPhone without Apple ID
Aug 08, 2016 | Apple iPhone 5
How do I remove a passcode from an IPhone 4s?
Do you mean the network passcode?If so, to remove the restriction, I suggest you can approach Wickedunlock.com and specify the country,locked network of the iPhone 4S.Based on the availability you can get their permanent remote unlock service and remove the network passcode.
Sep 29, 2014 | Apple iPhone 4S
Reset disabled iphone without using itunes
Connect your iphone to a computer with itunes and reset the disabled iphone
Dec 09, 2013 | Office Equipment & Supplies
How can you reset a forgotten password on the iphone a1203 phone
reset-oxaxc0rwhkhzilrwacqreyis-1-0.jpg How to Reset Password on iPhone
Jul 23, 2011 | Apple iPhone Smartphone
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
