Question about Us Leisure Storage Building. Stronghold 10 ft. x 8 ft. Resin Storage Shed
Roof rafters and roof peak and panels damaged
Snow build up on roof
Build a garage loft for storeage
If your garage is built like most, there are rafters just over the doors when they are open. We put bracing in between the rafters, then used the metal they use for pole barns for a "floor" on top of the rafters. We store a lot of stuff up there, and we put 2x6's on the ends to keeps things from accidentally falling.
Jan 03, 2018 | Building Materials
How do I determine the length of a rafter from from birdsmouth cut to peak
Using a rafter square determine the pitch of the roof.
Oct 12, 2014 | Garden
What is the length of a rafter on a 6 12 pitch in a 10 spand?
The if the sloped length of the truss rafter is L, the roof span S, the roof angle A, and the overhang V, then the equation for L is
L = V + R/(2cos(A))
The equivalent formula using the pitch, P, is
L = V + (R/2)sqrt(1+P2)
Oct 04, 2014 | Computers & Internet
How to build a dirt floor 20 by 20 shed
Put posts in ground.
Middle posts taller so roof will have slope
Nail 2x4s across from post to post to hold siding.
One row of 2x4s around bottom, 2 rows 2x4s around middle,
1 row 2x6s or 2x8 around top.
2x6s 2x8 will hold rafters
Nail 4x8 sheets treated plywood onto the 2x4s to make walls.
Install joists across top of structure from one wall to the other wall
Install rafters at correct angle to match slope of roof, be careful to each rafter exactly the same.
Rafters sit on outside wall
http://waterheatertimer.org/images/Pole-barn.jpg
Gene
Sep 01, 2014 | Hardware & Accessories
I had a new roof up on my house about 6 years ago. I just went into my attic and found wood that was rotten and was not replaced by the roofer. How can I replace the wood?
that would depend on if what you wish replaced are rafters, trusses or sheeting. rafters and trusses can have new pieces cut to fit and 'married' in bridging any weak areas. unfortunately, sheeting replacement means stripping shingle and paper to expose the damaged areas, cutting them out, new sheeting installed, repaper and reshingle. Hope you got a warranty from the contractor.
Oct 25, 2013 | Dometic Rooftop RV Air Conditioner
What is the best way to hang my punching bag up to avoid it falling down?
The best way is to hang it with chains around a rafter in your ceiling, however you should check first to ensure that the rafter is big enough to hold the weight. Also avoid hanging from trussed roofs, as this could be quite dangerous if the roof eventually failed.
Jul 09, 2012 | Boxing
What is the best way to hang my boxing bag up to avoid it falling down?
The best way is to hang it with chains around arafter in your ceiling, however you should check first to ensure that therafter is big enough to hold the weight. Also avoid hanging from trussed roofs,as this could be quite dangerous if the roof eventually failed.
How do find the roof rafters in a pop top.
Hi; Try using a electronic stud finder and switch to metal detection. Or maybe call or google the company that built the popup. Sometimes they can tell You exactly where to make Your cuts...alpharome416
Feb 10, 2010 | Dometic Rooftop RV Air Conditioner
Roof Decking for Galveston County Texas
http://www.informationdestination.cengage.com/ReferenceContent/Roofing/Plywood%20Roof%20Decking.pdf
If you have a plywood roof deck, make sure that you have at least 15/32" (or ½") plywood thickness if the rafters are set at sixteen inches (16") on center. If your rafters are twenty-four inches (24") on center, it is recommended that your plywood is at least 5/8" inches thick. All plywood should be Exposure 1 Rated plywood and be rated for structural use by the APA-The Engineered Wood Association. This is indicated by a stamp on the plywood that states "32/16" rated. What this means is that particular board is rated for sub-flooring where the floor joists are 16" on center and for roof decking where the rafter or roof joists are 32" on center. The APA recommends a 1/8" gap be left between adjacent panels of plywood/OSB.
please rate this answer as a FIXYA! thanks
Mar 05, 2009 | Jensen JER-422 Universal Remote Control
Us Leisure Storage Building. Stronghold 10 ft. x 8 ft. Resin Storage Shed Logo
107 people viewed this question
Top Us Leisure Garden Experts
john h
Tom Chichester
Are you an Us Leisure Garden Expert? Answer questions, earn points and help others
