Question about Vehicle Parts & Accessories
How does the rear differancle from 1995 ram 1500be removed
    Problem Solver:
  • 31 Answers
Put unit up on jack stands ( under frame) remove rear tires, remove drive shaft, unbolt 8 bolts from your spring hangars under the differential and it should come right out.
Posted on Nov 05, 2014
Oil pressure light comes on every now and again 1995 dodge ram van b2500 5.9l non turbo
The only way to know if you need engine repair or you have a bad sender is to hook up an oil pressure test gage to the sender port and manually check the pressure. You will need the deep oil pressure sending unit removal tool to get the sender out (I did this).
Nov 09, 2016 | 1995 Dodge Ram 2500
How to change thermostat in 1995 dodge ram 2500
drain the rad into a pail.
remove the upper rad hose from the thermostat housing.
remove the thermostat housing
remove the gasket/seal (from housing or engine)
remove thermostat
install ne stat & gasket/seal
reinstall housing and hose.
close off rad bottom valve
refill rad with new coolant (with cap off run engine until warm
top up fluid to neck) replace cap.
dispose of old fluid at environmental recycle center
Feb 11, 2015 | 1995 Dodge Ram 2500
1995 dodge 4x4 1500 ram speedometer quit working , won't go into overdrive , the 4 wheel drive will not en gauge , I have replace the speed sensor on the rear end and replace the speed sensor on the t
The sensor in the differential is for the ABS. Did you replace the sensor for the speedometer in the end of the transmission?
And is the check engine light on ?
Jul 04, 2013 | Cars & Trucks
1995 dodge ram 2500 third brake light works but the rear brake lights don't work
The circuit goes from the brake light switch thru the turn signal switch and uses the same bulbs as the rear turn signals. I would check for power in and out of that switch next.
Jan 08, 2013 | 1995 Dodge Ram 2500
I have a 1995 dodge ram 2500 cummins the abs and brake lights are on and the cruise control is not working? I have replaced the master cylinder and the speed sensor in the rear axle
The warning lights mean there should be a trouble code stored in the body computer. I would start there.
When the ABS system is inop it may prevent the cruise from working too. Sometimes a hydraulic brake system failure will turn the ABS light on too. After repairs you would need to scan the system to turn the light off with most vehicles.
Are the brake lights in the rear of the truck staying on ?
Jul 03, 2012 | 1995 Dodge Ram 2500
I have a 1995 Dodge Ram 1500 4 x 4, I need to remove the Left Axle from the Axle Housing to replace seals and U-joint. How do I remove the Axle from the Axle Housing?
Remove wheel....remove brakes....three bolts behind the hub (9/16" 12pt socket)....1 11/16" nut in center of hub needs to be removed. You will need a slide hammer type puller to hook onto the hub for removal. (you should replace the hub...prone to go bad)....axle will now slide out through opening where the hub was.
Oct 27, 2009 | 1995 Dodge Ram
How to install rear window on 1995 dodge ram
Chrysler Full-Size Trucks 1989-1996 Repair Guide
Stationary Side or Rear Window
(see Figures 1, 2 and 3)
You'll need an assistant for this job.
  1. Remove the moldings surrounding the glass.
  2. Have your assistant stand outside and support the glass.
  3. Working from the inside truck, start at one upper corner and work the weatherstripping across the top of the glass, pulling the weatherstripping down and pushing outward on the glass until your assistant can grab the glass and lift it out.
Fig. 1: Work the weatherstrip seal in until fully seated
  1. Remove the weatherstripping from the glass.
Fig. 2: Exploded view of the vent window mounting-Dakota models
Fig. 3: Exploded view of a common rear window mounting
To install:
  1. Clean the weatherstripping, glass and glass opening with solvent to remove all old sealer.
  2. Apply liquid butyl sealer, in the glass channel of the weatherstripping and install the weatherstripping on the glass.
  3. Apply a bead of sealer to the opening flange and in the inner flange crevice of the weatherstripping lip.
  4. Place a length of strong cord, such as butcher's twine, in the flange crevice of the weatherstripping. The cord should go all the way around the weatherstripping with the ends, about 18 in. (457mm) long each, hanging down together at the bottom center of the window.
  5. Apply soapy water to the weatherstripping lip.
  6. Have your assistant position the window assembly in the channel from the outside, applying firm inward pressure.
  7. From inside, you guide the lip of the weatherstripping into place using the cord, working each end alternately, until the window is locked in place.
  8. Remove the cord, clean the glass and weatherstripping of excess sealer and leak test the window.
  9. Install the moldings.
I hope help you with this (remember rated this help) Good luck.
Oct 06, 2009 | 1995 Dodge Ram
My 1995 Dodge Ram Has a Lot of Play in the rear
Bearings. seals ,gaskets, crush sleeve, diffy. fluid and possibly ring gear and pinion .
Jun 29, 2009 | 1995 Dodge Ram 2500
1995 Dodge ram rear end noise
Replace the axle tie bar bushes.They have worn out,
Reverse light switch on 1995 Dodge Ram 1500
switch is just above trans pan and below shift linkage requires a thin (crome 1" socket) to remove
Jun 01, 2009 | 1999 Dodge Ram
Vehicle Parts & Accessories Logo
41 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
