Question about HP H-ig41-uatx Motherboard Intel G41 500b 608883-001 100% Working
Hp h-ig41- uatx motherboard wen i plug in the power supply the big intel i c gets hot wats the problem
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
Dear! The main Intel chip problem.if very Heat up then not repairable. To change your mainboard.
Posted on Jan 11, 2015
2 Suggested Answers
bahratt
  • 561 Answers
SOURCE: HP dv2000 fails when power supply connected
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
Posted on Jan 10, 2010
When I plug in my power supply the CPU cooler automatically comes on along with the motherboards light flashing repeatebly. How would I fix this? It worked beore this perectly.
check that the power switch on the case isn't stuck or that the power connection on the motherboard isn't shorted. (not the power supply, but the connection to the switch).
Oct 26, 2014 | Computers & Internet
I have an Hp m260n. I just need to find out what type of case it has (ATX or uATX).
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00026876
Motherboard: ASUS P4SD Motherboard Specifications
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00022505&lc=en&cc=us&dlc=en#c00022505_doc
Board Form Factor: uATX
uATX stands for Micro-ATX,
http://en.wikipedia.org/wiki/MicroATX
http://en.wikipedia.org/wiki/Computer_form_factor
http://en.wikipedia.org/wiki/Computer_form_factor#Tabular_information
HOWEVER, the Power Supply is an ATX form factor,
http://www.911forpcs.com/hp-media-center-power-supply.html
,of a sort.
Form Factor related directly to desktop computer Motherboards.
Now has 'evolved' to relate to the computer case, and Power Supply.
When referring to a Power Supply, and the ATX form factor; you are not only referring to the size, and shape of the Power Supply's case; but also the type of power cables used, and the technology used within.
Size and shape of an ATX power supply is approximately;
6 Inches Wide, 5.5 Inches Long, and 3.5 Inches in Height.
(152.39mm Wide, 139.69mm Long, and 88.89mm in Height)
Power cables included with Power Supply's nowadays, will include all the power cables you'll need, with probably some left over.
HOWEVER, looking at the 'ATX' form factor designated for your computer, to wit from the ad above, it does NOT fit the above size, and shape.
More like 6 Inches Wide, 4 Inches Long, and 3.5 Inches in Height.
Looks like they just crammed everything into one small box.
Remove motherboard, and all internal hardware, into a new computer case?
No prob!
Most Mid-Tower to Full Tower size computer cases, will have a Support Plate that accommodates a Micro-ATX form factor motherboard, OR an ATX form factor motherboard.
Just look at the Support Plate mounting holes.
Ones for a Micro-ATX (uATX) motherboard, will have uATX next to them, or MATX, or mATX.
Ones for an ATX motherboard, will have ATX next to them.
However check the computer case manufacturer info to be sure.
[ The motherboard mounts to a Support Plate.
The Support Plate can be an integral part of the metal frame, of the computer case; or a separate metal plate that attaches to the computer case metal frame ]
Not what you had in mind Joel? Post back in a Comment.
Regards,
joecoolvette
Feb 17, 2013 | HP Media Center PC M260n (DF200A#ABA) PC...
HOW TO DOWNLOAD BINARY FILE FOR BIOS OF INTEL 41RQ MOTHERBOARD
here you go download from there http://www.intel.com/p/en_US/support/highlights/dsktpboards/dg41rq/
Dec 31, 2012 | Intel Desktop Board DG41RQ Essential...
laties drivers download from there http://www.intel.com/p/en_US/support/highlights/dsktpboards/dg41rq/
I bought a HP 6710f Pavillion desktop, running windows 7, and found out it only has a 250 watt power supply. I turned around and bought an Antec Greenwatts 500 watt ATX 12v v2.3 psu to install for future...
Presuming you mean the Earthwatts 500:
Should work, though the Earthwatts has the 24 pin ATX instead of the 20-pin.
http://www.atxpowersupplies.com/manuals/Antec-Earthwatts-EA-500D-user-manual.pdf
You just need to snap the 24-pin connector apart to make it work as a 20-pin. It can be snapped back together for future motherboards.
The Bestec is just a standard ATX power supply
Mar 23, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
I have an Intel(R) Core 2Duo processor with dg31pr motherboard can get extremely hot the problem is that it is use daily 11to 15 hours or more with out rest because when i leave my bro sit.Can i install...
use a 12volts fan and connect to the power supply. Not on the motherboard because that will add load to its performance. Tap the positive wire of the fan to the yellow wire of the connector.. the negative wire of the fan on the black wire of the power supply connector.
May 17, 2010 | Office Equipment & Supplies
Sometimes show 2.4Ghz celeron Processor and sometime 1.86A also
change your power supply and rating your power supply must be
350watt or 400 watt
Feb 26, 2008 | Intel D845GVFNL : uATX Socket 478 FSB533...
HP H-ig41-uatx Motherboard Intel G41 500b 608883-001 100% Working Logo
161 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
