Install power board - Computers & Internet
58" Samsung TV, Model UN58H5202AFXZC: Multiple successive failures of power board.
The "repair person" was what is known as a parts swapper. What was needed was to find out what was causing the power supply boards to fail. My guess is a short in one of the outputs.
Jul 14, 2017 | Samsung Televison & Video
How Do I repair my LG LED TV that does not power on?
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
You can repair it very easily, within seconds.
Sep 16, 2015 | LG Televison & Video
To fix no video Vizio E470i-A0 TV
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 21, 2015 | Vizio Televison & Video
HOW MUCH IS IT FOR A POWER SUPPLY FOR A 40 INCH LCD WITH LABOR
You can easially install the board yourself in under 10 minutes and you can get the Power board with installation instructions from www.tvrepairworld.com they will also let you know which is the correct board for your model. A shop will be expensive about 200 for the board and about 100 for labor depending on the shop.
Feb 08, 2012 | Coby Televison & Video
Sata power supply with ide only mother board?
If all the motherboard has is IDE connectors,then you can with an add in card. To do this you need to run the installation floppy during a fresh windows installation when it prompts for 3rd party scsi or raid drivers. I'd take the easy road & install a slave drive on the IDE or run an external hard drive in a usb port. Or the ultimate option,build a system using a board with sata on it. Prices are way down on hardware in general,but it's not going to stay that way.
May 14, 2010 | Computers & Internet
Hoe to install the mother board
first install the processor. then the mother board places in the casing. screw it up. then add ram, hdd, dvd rom. at last connected the power cable, restart cable, hdd light, power light.
Jan 20, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Power running board failure
This is not really solving the problem, but my dealer told me that they could unplug the harness to keep the running boards in the down postion. The running boards have to be in the down position to make this happen.
Nov 18, 2008 | 2003 Mercury Mountaineer
Power problem
take every thing you have installed on the board off. power it up. if it comes up, install one item at a time and narrow the problem.
make sure your CPU is in correct orientation. and the power supply are correctly connected ot he board.
the fan on the CPU should come on when you power the board, and a indicator on the board should liteup.
if nothing happen. then you cooked the board.
Oct 22, 2008 | Mercury P4VM800M7 Motherboard
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
