Question about Facebook Apps
My cover page is messed up.. how do I get it back to normal?
The color is messed up, how do i get it back to normal?
the color is messed up how do i get it back to normal
Jul 19, 2012 | LG 42LG50 42 in. LCD HDTV
I am taking twelve, one page documents and converting them to a unified 12 page document. I have done this several times & everything works perfectly. This year, however, when I select the pages to...
I do not know what program you are using but it sounds like you may have a default paragraph or character style set up in the target document. For example if the document that you are copying from has a normal style that has bold setting and then you copy it into the target document that has a normal style with say italics, the normal style in the target document will apply.
This is the case in programs like quarkxpress and indesign. Hope this gives you some ideas to help you out.
Dec 09, 2010 | Computers & Internet
Breville RC3 Rice Cooker and Steamer Leaves starchy mess on work top when cooking rice, am I doing some thing wrong?
Thats normal when cooking rice!
If you dont want these starchy mess, try to cook less rice so that boiling water won't come off from the cover!
Nov 06, 2010 | Breville Kitchen Appliances - Others
I have a suoer usb box.. Was messing with it and now lost all channels except 2. I jus had the normal channels befor that.. any1 able to help.. thanks..
press menu. then just enter 1668. press enter on nagravision. select your provider. press auto scan. all stations will re tune. then exit. go back to menu then press 1570. it should say off on EMU down bottom of page, turn it back on. then it will be sorted
Jan 10, 2010 | StarTech.com StarView SV431USB 4-port KVM...
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Close the front cover of the printer.
Back cover is open
Close the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
If the printer does not start printing, press the Go button.
No paper fed manual feed slot
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
The printer memory is full and the printer cannot print full pages of a
document. See Solving print problems on page 6-15.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
Alarm doesn't go off when set. I've adjusted the time. Still nothing
Try removing the battery and unplugging it form the wall for a few hours. This will allow the microprocessor time to discharge and reset to it normal functions. After letting the Clock/Radio discharge, you can put the battery back in the Clock/Radio and see if it has reset itself to the factory setting.Then use the link (http://www.emersonradio.com/owners) copy the web page link and paste it into the address bar of you browser. It will take you to Emerson home page for owners manuals. There you can find your model clock radio and follow the instructions for resetting the clock radios functions. I hope this information helps you with your problem.
May 20, 2009 | Emerson Smartset Clock Radio
Brother 2040 printer. Toner speckles on all the pages.
Take the toner out, and shake it. Make sure you cover the holes or you will make a mess
Everytime I have had spots or streaks this has fixed it for me.
Hope this helps!
P.s. you may want to get a cleaner sheet and run it thought the rolls.
Jan 21, 2009 | Brother HL-2040 Laser Printer
Just changed both magenta and yellow toner cartridge on my color lazer. When I print the page comes out covered in blue, magenta and yellow streaks. i have re-installed everything and cleaned everything...
is that a new toner? or a refilled one?
its hard for you to ressolved the issue because you need to open all the cover in order to clean all the necessary mess.
try to send your printer to a repair center.
Aug 28, 2008 | Office Equipment & Supplies
Facebook Apps Logo
76 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
