Question about Bose in-ear headphones - Black with black/white cord
Broken wire in hologram
I have a broken wire inside hologram of bose ie2
Why does my bose RC-9 remote works only at close range?
1. The antenna inside (It looks like a coil of thick copper wire) gets broken or the solder breaks away.
2. The data cable has been coiled up (to make it neat and tidy). The data cable is the actual antenna to pick up the remote control signal.
Solutions :
1. The remote control can be repaired.
2. If the data cable is all coiled up, spread it out loose and this will make the remote control work much better.
Hope this helps :)
May 27, 2014 | Bose Televison & Video
Battery ? Mark
You should confirm that any battery you purchase has a "Motorola Original" hologram.
If you see a message on your display such as Invalid Battery or Unable to Charge,
take the following steps:
• Remove the battery and inspect it to confirm that it has a "Motorola Original" hologram;
• If there is no hologram, the battery is not a Motorola battery;
• If there is a hologram, replace the battery and try charging it again;
• If the message remains, contact a Motorola authorized service center.
Oct 23, 2013 | Cell Phones
Hi, My son has a pair of these headphones - he lost them and his friend found them in his drive. since getting them back only one ear is working. it looks like something has happened to them as the black...
$78 plus to replace via Amazon. Parts too expensive. Do it yourself fixes would not repair cosmetic damage. Young fellows like to look spiffy. And DIY takes time and may or may not work.
Jun 16, 2017 | Bose IE2 Headphones
The wiring in the inside of the headphones is messed up
the wire inside the cable has broken
are these headphones real? orginal bose?
if so i would contact bose because the wire shouldnt break (under normal use)
May 14, 2010 | Bose in-ear headphones - Black with...
BOSE RADIO
The line fuse for these sets is inside the radio on a printed circuit board. NOTE: for your safety, disconnect the radio from its power source before you open the case and poke around inside. The best way to check the fuse is with an ohm meter, but you can probably check it visually using a strong flashlight. There should be a wire filament running the length of the fuse. If it's intact, so is the fuse. If it's broken or not visible at all, the fuse is "blown" and needs to be replaced. If the fuse checks out ok, the power transformert is likely bad -- a problem that these sets are notorious for. Bose will charge you $100 for the transformer repair (unless the set is still under warranty), and having it done is strictly a matter of personal choice. My choice would be to sell the Bose on eBay as a "tech special" and pick up one of the newer HD radios. They offer much better sound at a much lower price.
Bill B.
May 14, 2009 | Bose Wave Radio
Bose Companion 3. Speakers are very faint in sound. The touch pad seem inoperable. (the green light on pad does not come on.)
Check first that you have connected the speaker to the right output. For example on many computer there is an aux output marked in blue that can give you this problem.
If the problem does not depend from the source, then that sounds like an internal fault on your Bose system.
Leave the Bose unplugged from power and from computer for one hour, to get rid of electrostatic charges accumulated inside capacitors.
If that does not get rid of the problem, then there is an internal fault, either a short on speaker wiring, or a fault on the internal amp circuit board.
Mar 05, 2009 | Bose Companion 3 Computer Speakers
My right earphone won't play
Sound not coming out of one side of the headphone is an indication of connection failure, so that means you have to see where its 'broken' from, either inside the headphone on on the wire somewhere. Usually it happens at the jack, especially if you use an ipod as it tends to get moved alot in pockets, etc..
If this is the case, you could try to cut the wire from where you suspect its broken, and get a 3.5mm (or whatever the original size is) replacement (Do-it-yourself) jack from Radio shack or electronics store.
THen you would have to cut the wire, strip the the rubber coating off, and then if applicable, carefully strip the very thin layer of further insulation thats on the wire it self. Otherwise you would directly connect the cables to the prongs/connections located on the replacement jack. And depending on the jack you would screw it in place or soldier it with soldier and soldiering gun.
If its broken in the headphone or at the headphone, thats much harder to do as you would have to open the head/earphone case and soldier it that way and get it back together in one piece.
Next time don't buy bose headphones and by something cheaper, bose isn't that great, skullcandy is pretty good too. Sennheiser is the best though in my opinion. albieit its expensive too..
Feb 23, 2009 | Bose QuietComfort 2 Consumer Headphones
Bose 141 will not work
hello in this case this boxes are sealed to ensure a rich sound do this check where they bond together try to apart, im sure you already check with a baterry and ohmeter in the connector of the speaker see how many ohms you have about 4/8 omhs or even a broken wire inside the cabinet cause very old .....saludos
Dec 02, 2008 | Bose 141 Main / Stereo Speaker
Dropped phone.replaced screen.now theres a hologram.
Erm.. all i can think of is that youve placed the screen in wrong ? if so check it and if this isnt the problem i suggest you get a lcd screen flex. Hope i helped :)
Aug 05, 2007 | Nokia 6233 Cellular Phone
Bose  in-ear headphones - Black with black/white cord Logo
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
