Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Keep plugging in the usb cable and different things pop out
I keep plugging in the usb cable and differnt things pop out than the usal music,videos,pictures etc.... it says .cache dic fonts vsh the psp mode is 2001 slim silver please help.
  • 52 Answers
Your psp is in Flash 0 mode. To take it of Flash 0 mode you turn off your psp completely. Once thats done you want to hold the R button and turn on the psp while holding R. This will take you to recovery mode. Only do the step that tells you to click Flash 0
Posted on Jun 26, 2009
Tablet won't stay powered with out being plugged in
I have seen this several times now. It is usally do to 1 or 2 things that you can try to resolve this. The first issue is that these tablets are very battery eaters and you need to charge it for atleast 24hrs with power cable before you activate it. The USB cable will only keep the tablet charged if u have a good 50precent charge in it first. I have had the WI FI discharge a full battery in 2hrs plug in to the usb. The power adpter needs to be used when u can or it will discharge the batt unless u power down the unit not just let it go to sleep.
Go to the settings tab..then to battery..and u can see what the rate of discharge is ..ie..wifi and wallpaper and idle all can be adjusted to max battery life and make sure you turn it off when u can.
Hope this helps.
Chad Man
Sep 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
I keep getting a connection Error Message. Please Check that USB cable is connected and power switch is turnedl. I just upgraded to a new computer from and older model computer
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. If you're using a laptop, keep trying different USB ports until you find one that works. Good luck!
Apr 29, 2011 | Singer CE-200 Quantum Futura Computerized...
Which printer cable best suites my needs?
Printer Cables are one of those things you never give much thought to until you need one. With the invention of the USB port it has made it quite easy to install a new printer. You simply plug your printer into the Usb port on your pc. With that said there are some things you need to be aware of that can affect the quality of your printing needs. There are many different types of printer cables to choose from. They range from very cheap to very costly. If you are just using your printer for everyday use you can get by with a standard usb printer cable but if you plan on using your printer for photos or any type of graphics work you need to consider a better quality printer cable. Which will give you a better quality print. Listed below is a brief explanation of the different of the different types of available printer cables. Keep in mind this is just a fraction of the difference's in printer cables and some cables may not applay to your printer. Be sure to click on the tabs above to find just the right printer cable.
Aug 12, 2010 | Brother Office Equipment & Supplies
How do i start up my labtop without using a cable to access the internet
Login to the default router config page from your desktop pc. This is usually plugged straight into the router via a network cable. Go to http://192.168.1.1 in w web browser. Default login is usally "Admin/Admin" or "Admin/Password" keep trying different combos.
You may also need to press the "Reset" button on the back of the router.
Nov 25, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Set up password on blitzz bwa711 router
Nov 25, 2009 | Blitzz Technology BWA711 Router...
Battery level shows about half. Charging arrow doesn't show.
Try a different usb cable or mabey the actual usb port
Jul 09, 2009 | SanDisk Sansa e250 MP3 Player
I try to download songs, but AutoPlay keeps popping up.
Test another USB port on your computer, and see if you get the same result. If you get the same result, the USB cable may be faulty.
Here is a test you can do to see if the problem really is the USB cable, or if it is something else:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 02, 2009 | Philips SA3025/37 Flash MP3 Player
My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
When plugged into computer it says "usb device not recognized"
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Nov 26, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
