Question about KitchenAid KHWS02R Front Load Washer
What does it mean when Kitchenaid front load code H then F flashing?
My kitchenaid dishwasher kude40fxss4 stops after few minutes into any cycle then the front blue light starts flashing. If I press start again it will start but it'll stop with the blue light flashing
Hello. I've attached images that show the error code chart for your series unit--look at the lights blinking, which ones and how many times they blink.Read the 1st instructions carefully to put the washer into diagnostic mode. You will have to go through the charts to find out what specific code you're getting and what it means. I hope this documentation helps you!
Oct 14, 2015 | KitchenAid Dishwashers
KitchenAid Electric Range KERS807 Oven won't do anything, flashes S3E3 code
Do you mean an F3-E3 code? I've never seen a KitchenAid S3 code.
The F3 code means that the oven temperature sensor is bad. The E3 indicates that the sensor indicated an excessively high temp during the clean cycle.
Please determine the full model number of your range to ensure that you get the correct sensor. The sensor costs between $75-80, depending on the vendor. I used the KERS807SSS02 for a guide. www.searspartsdirect.com and http://www.appliancepartspros.com both have the sensor in stock.
If the range is still under warranty, contact KitchenAid for the repair.
I hope this helps.
Apr 30, 2012 | Kitchen Ranges
I'm getting an F2 code on my Kitchaide front load
F2 on this unit is long drain. Take the front lower cover off (3 screws on the bottom) and you will see a round white cover about 4 inches round. That is the pump clean out. Before you twist that cap off be aware the water will come out have some towels ready. Take the cap off and you will see all the junk in there remove it and replace the cap. Thats it good luck..
Jun 06, 2011 | KitchenAid KHWS01PMT Front Load Washer
The washer will not spin or run.. The code that comes up is FdL?
I think that means front door latch make sure there isnt something in the door track
Feb 15, 2011 | KitchenAid KHWS02R Front Load Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Contol on light blinking, kitchenaide front loading automatic washer, two years old
if this is a flash fault code consult your manual to see what the code is telling you then relist the code for some more advice.
Jan 20, 2008 | KitchenAid KHWS02R Front Load Washer
KitchenAid KHWS02R Front Load Washer Logo
44 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
