Question about Field & Stream 50 lb. Digital Scale
Change from lb to kg? - Field & Stream 50 lb. Digital Scale
How do I change it from KG to pounds?
That basic conversion is 1 KG = 2.2 LB. so if you have 5 KG, the you have 11 LB.
There are a number of online calculators that will do more exact conversions for you.
Apr 25, 2015 | Health & Beauty
How to change a Bfm883dqn 01 from kg to lb
Hold the 1st button down until kg pops up on the screen. Let button go, hit 1st button again, it should change to lb. hit select button. Should stay on lbs.
Jul 06, 2012 | Healthometer Health o meter BFM883DQN 01...
How we change from lp to kg
lb to kg. there are approx 2.2 lb in 1 kilo
Jun 14, 2012 | Computers & Internet
St and lb ?
just type the conversions you need into Google - it will automatically convert them for you
1 lb is 545g
Sep 13, 2009 | Computers & Internet
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Which is the head torke santa fe 2003 2.4cc?
Tightening torque
With used parts (head bolt, cylinder head cylinder block) : 20Nm (200 kg.cm, 14 lb.ft) + 90° + 90° With new parts (even if only one thing is replaced) : 64Nm (640 kg.cm, 46 lb.ft) + release+20Nm (200 kg.cm, 14 lb.ft) + 90° + 90°
Jun 06, 2009 | 2003 Hyundai Santa Fe
Conair ww17 scale measures in kg not lb.
There is a switch on the bottom of the scale on mine to use either lb. or kg.
Dec 11, 2008 | Conair Large Digital Display Memory...
Field & Stream 50 lb. Digital Scale Logo
26 people viewed this question
Top Field & Stream Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Field & Stream Office Equipment and Supply Expert? Answer questions, earn points and help others
