Question about VillaWare Mini-Perk 5120-05 Coffee Maker
Where can I get a replacement glass knob for my VillaWare Model 5120-12 Coffee Percolator?
  • Wesley H
    Wesley H Nov 02, 2014
    I need a lid would you sell yours for parts wesleyh@austin.rr.com... they do not make the knob anymore cuisinart prc 12 knob fits but is the wrong shape
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Farberware millenium coffee percolator does not heat
There is a thermostat in the bottom of the percolator that is broken. It would normally cut in to perc the coffee and then cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to bypass the thermostat and just unplug the percolator, time it for 1 minute per cup.
Mar 04, 2013 | Farberware Coffee Makers & Espresso...
Replacing Farberware LJF13-296 coffee percolator main element
First of all I have access to most parts.I can also make repairs or advise you to do it.I manufactured coffee urns and convection ovens for fsrberware. I also repaired 3 d different sizes of perks.reach m e a t pollock57@hotmail.com.thanks frank
Nov 11, 2012 | Coffee Makers & Espresso Machines
I have a pyrex percolator Glass, only I have broken the stem that holds the basket. does pyrex have replacements and how do I contact them.
You can start by calling Pyrex sales at http://www.shopworldkitchen.com/pyrex, buy Google for "Pyrex Parts" to find lots of 3rd party parts providers. Depends on how old the percolator is.
Mar 18, 2011 | Coffee Makers & Espresso Machines
I am looking for a replacement black handle for a 100 cup West Bend coffee percolator. One is broken and hence does not clap the lid properly
if you can find the model number for your product you should be able to order a replacement handle from Ihe following site:
http://www.westbend.com/catalog.cfm?dest=dir&linkid=125&linkon=subcategory
Sorry someone has not responded sooner.
Jan 07, 2011 | West Bend PERCOLATOR
Where do I find a glass Corningware percolator lid insert?
You can get parts for it on eBay under corning coffee pot parts. Good luck Ron
May 31, 2010 | Coffee Makers & Espresso Machines
Looking the glass knob for the farberware FCP512 percolator
Hi. Go to eBay and search for farberware coffee pot parts. Good luck
Jan 27, 2010 | Faberware Coffee Makers & Espresso...
The bulb on top of my Melitta Java perk Model #MEP-10 Percolator is broken and I would like to purchase another if I can.
Go to the hardware store and buy a porcelain or stainless steel cabinet knob that will fit over the hole in the percolator top. Discard the screw that comes with the knob and replace it with a shorter (maybe 3/8") stainless steel version (shorter because the top of the percolator is a lot thinner than a cabinet). Then, buy a couple of neoprene washers and a stainless steel fender washer. Prepare the percolator top by using a hammer and a small piece of wood or something to flatten out the metal around where the old percolator top used to fit. Now you can start putting things together--slip the fender washer over the screw, then one of the neoprene washers and put it through the hole in the percolator top from the inside. Then slip the other neoprene washer over the protruding screw and screw the cabinet knob down, sandwiching the whole assembly nice and tight. Finally, tape a dollar to the old plastic percolator top and throw it away so you can say you've thrown away something.
Dec 07, 2009 | Coffee Makers & Espresso Machines
VillaWare Mini-Perk 5120-05 Coffee Maker Logo
Top VillaWare Coffee Makers & Espresso Machines Experts
Tom Chichester
Are you a VillaWare Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
