SOURCE: setup canon 450d remote control
There should be no set-up process. Plug in the receiver to the socket under the rubberised flap on the left side of the body, extend any ariel on the release itself, make sure any switches are on and away you go. There may be additional channels on the set in case you have interference from other wireless release users in your vicinity.
SOURCE: Forgot manual abroad, where can I get another
You can download the complete instruction manual in PDF format by clicking this link.
Hope this solves your problem. Thanks for using FixYa.
SOURCE: Canon eOS 450d not clicking on AF mode
this may have to do with the lens rather than the camera, try swapping the lens with another one and see if the same problem happens in AF mode with the new, borrowed lens, also remove lens and check that the gold connector between the two are clean carefully wipe with a dry q tip but be careful not to allow dirt to fall into camera body.
