Ricoh Aficio 1045 Black and White Copier Logo
o
ongjunyu Posted on May 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the corona wire placed in iRC3380i - Ricoh Aficio 1045 Black and White Copier
Marius Chiriac
Level 2:
  • Ricoh Expert 242 Answers
  • Posted on May 13, 2014
Marius Chiriac
Ricoh Expert
Level 2:
Answers
242
Questions
0
Helped
114232
Points
658
Hello, this model has no corona wire, insted it has a trnsfer roller, the roller is placed on the dor of the machine and it is made from a sponge like material.
Can i use corona wire in place of the PTC heater
Corona wire is very fine gold paled wire that carries a HV during the copy process. not used for heating
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Some places are omitted from the copies i made from my copier i.e.blank, rub off
I THINK THE CORONA WIRE PROBLEM......RUSTY EFFECT , TRY INSERT NEW CORONA WIRE..... THERE WILL BE MUCH
IMPROVEMENT
Error e000061 0001
61 is a laser code first check the primary corona assy. are the corona wires in the proper place on the the little end blocks in the proper groove. they should be in the groove thats closets to the grid wire the wire on top of the unit. Both ends of the corona wire, should be in that top groove, not one on top and the other on the bottom. ) or should say potential voltage on the drum. Since it is not equal both sides, one side being darker, sounds like the corona wire is out of place.
if you need more help you cab get the service manual fo ir5000r from the below link:
http://goo.gl/fG9SAz
good luck
Corona wire problem
Hi, you can clean the corona wire easy, just follow those steps:
1) Turn of printer power and unplug all cord including phone cord.
2) Make sure the scanner is closed, then lift open the top cover by its handle.
3) Remove both the drum unit and toner cartridge assembly for the color desired to be replaced.
4) With the drum unit removed, push down the GREEN lock lever to remove the toner cartridge.
5) Slide the GREEN tab left to right several times to clean the unit's primary corona wire.
6) Before installing new toner cartridge, shake it from side to side to distribute toner.
7) Remove protective cover from cartridge.
8) Insert cartridge into drum unit until it snaps in place.
9) Ensure that you are inserting the correct color toner cartridge into its proper place and then slide the drum unit into the printer.
10) Close the top of the machine and then reconnect all cords; turn on power to ensure proper installation.
1helpful
I have a minolta CS pro and got a C0210 code. Please give answer in layman's terms please.
Hello this is going to be an issue with corona wires it could be the charge corna unit or the transfer seperation unit check the corna wires and springs that hold the corona wires in place if corona wire is bad replace also check for arching on the ends of the corona asseblys you can normally smell the arching or you can just replace the charge unit for the drum unit and the transfer seperation unit as well
CAN any one help me for solve this problem. My canon copier Clc 700 show error message : E061 thank tour for your help.
this is hardware technical problem if you can do that then follow the following thing or show it to service center.
changed the temperature and humity sensor, cleaned the door switch, and changed the primary corona .first check the primary corona assy. are the corona wires in the proper place on the the little end blocks in the proper groove. they should be in the groove thats closets to the grid wire the wire on top of the unit. Both ends of the corona wire, should be in that top groove, not one on top and the other on the bottom. )61 is a laser code, or should say potential voltage on the drum. Since it is not equal both sides, one side being darker, sounds like the corona wire is out of place.
Have a nice day and do not forget to rate please...!
1helpful
Corona cleaning does not solve error message
You will need to replace the drum unit on the printer.
8helpful
I have Ricoh Afisio Copier and I have error code SC301
That mean that you have problem with the charge corona, i'm not sure for which model do you talk about but it should be when you open the front door it has one black wheel, under the wheel has a black oblong(the corona) from which come out a wire which is connected near, so when you will locate that part(the corona) you will see that the part is attached to metal plate with one bolt under, so unscrew the bolt and pull the corona towards you but carefully and straight to not damage the drum when you will pull out the corona you will see that inside has two or one string wire, see do the wire is broken if is broken it will need to be replaced, if the wire is not broken you will see do the part(corona is dirty if it is , clean it up with clean cloth or if you have on hand put some pure alcohol 96% on the clothe and clean it up after that insert the part(corona) inside. you can't make mistake on the path where you need to return it has a rails on both sides if you do not set the corona on the rails it will do not enter, do not use to much force if do not want to enter try again. after you will place in it place don't forget to attach the connect the wire and screw the bolt. When you will do this turn the machine on again and see do will the SC 301 disappear, if do not disappear you will need to call service because some part need to be replaced.
Please rate the post if was helpful for you for i to know does this was helpful or not for to know to post some more information
4helpful
2answers
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
14helpful
8answers
Corona wire AND MORE SPAM 1-800-975-0148
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
