Question about Minn Kota On Board Charger
Why does battery charger read check bettery connection
Battery and or charger won't work. Charged a full 18 hrs. Help
Possible suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
Nov 27, 2015 | Motorcycles
The battery isn't charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Jul 24, 2012 | LG Accolade VX5600 Standard Battery
My betteries charge very fast and in les then five minuts they'r dead
Batteries are usually bad when this happens. Suggest searching internet for replacement batteries.
Jul 09, 2012 | DreamGear Power Base Dual Charger for...
My phone is not charging. when the charger is connected it shows the battery icon blinking as while on charging. but it is not charging & the battery was also OK .
First Option:
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 11, 2010 | Motorola Mobility ROKR E6 Smartphone
Pt4235 norcent turn on and of by it self please help
For that open back cover of laptop then reattach the ram memory and battery .Make sure your battery is working fine.
Then check.
Also find motherboard after open back cover pull cmos cell from motherboard for 10 minutes then check.
If still same issue then your motherboard chip set has internal issue so after trouble shooting above thing if still same issue then take it to nearest laptop service center because your motherboard need repairing.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 06, 2010 | Acer Aspire 9810-6829 Notebook
Battery will not take a charge, i do have it plug in now,it's showing that it's connected.
you should check ur charger first if it is ok then check ur charing pin inside ur device.check ur bettery also some time betteries have problems.
Dec 04, 2009 | SanDisk Sansa Clip MP3 Player
Chaina n98gb
plz change your mobile bettery
May 30, 2009 | Nokia N95 Cellular Phone
Charge meter problem
i have sony ericsson w800i
when i put to phone charge does not work charge, sometime connect charger & start charge
Jan 12, 2009 | Sony Ericsson W800i Cellular Phone
Battery?
     You have to change the bettery but also check that the board from which bettery pass the supply it could also be short due to water.In this case it is not necessary that battery could be damaged.
 Thanks and dont forget to rate .
Nov 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Minn Kota On Board Charger Logo
62 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
