Question about Makita Saws
Circular saw won't turn off.
I made a cut, turned to set the saw down, and it kept running. The motor wouldn't stop until I unplugged it.
efs_perpends
  • 1996 Answers
SOURCE: where is the lock button for the skill saw
I can't seem to access the parts view for your model, because of its age.
But I'm thinking skil probably hasn't changed things all that much.
Take a look at the 5450 and see if this doesn't help any...click here ...and scroll to page 7.
Posted on Apr 10, 2009
  • 120 Answers
SOURCE: 10" sears radial arm saw stopped running.
The brushed may need to be replaced.
Posted on Jun 08, 2009
  • 11 Answers
SOURCE: My 7 1/4 in Craftsman circular saw stops running.
Is there anything jammed between the blade and the body/guard of the saw?
Posted on Jun 26, 2009
rcalorisian
  • 313 Answers
SOURCE: My Skil 5250 Circular Saw does not turn on
If you are pretty handy you can fix it your self. The part you will be looking for will look like this ( $8.00 PART) Look below for a place to buy it.
The diagram is here
Posted on Sep 09, 2009
Testimonial: "Thanks. I ordered the part. Let's hope that is it."
  • 13702 Answers
SOURCE: My Craftsman 8 1/4 Radial Arm saw
tighten retaining bolt if still spins remove bolt and add a washer to the out side of blade between the bolt head and retaining washer and retighten
Posted on Jan 31, 2010
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
My hitachi c8fb2 saw won't turn off
It sounds like your switch has a short circuit. It is quite unusual for this to happen and due to the nature of the fault I would highly advise not using the saw until it is sorted. If you are uneasy about working on the electrical parts of this you can find your nearest service agent on their website. Hitachi service page, put ypur postcode in the box on the top right.
Apr 14, 2013 | Hitachi Power Tools 8-1/2" SLIDE COMPOUND...
I bent the depth of cut scale on a Craftsman 7-1/4 in. Circular Saw. How to true it so I can again set correct depths?
With the saw unplugged, lay it upside down on a bench or table. Put a small scrap of 2x4 against the blade and adjust until the depth of the blade matches the thickness of the 2x4. Lock it in place, Then bend or adjust the depth scale so that it reads 1-1/2 inches. Good luck.
Dec 10, 2012 | Sears Craftsman 7-1/4 in. Circular Saw...
Circular saw won't start after having cut pavers
You fried the motor and most of the time it isn't worth repairing, since the parts will cost you more that a replacement saw.
If you are going to continue to cut pavers, suggest you either take it very slow and cut 1 or .5 paver and then let it cool down. But a water cooled tile saw would be better.
Jun 24, 2011 | Saws
Motor runs, saw not cutting
Hi
If motor is running and the blade is not turnning the motor pinion gear is damage.
Go see this link for parts diagram.
http://www.ereplacementparts.com/skil-5500-f012550000-714-circular-saw-parts-c-130_160_843.html
Feb 07, 2011 | Skil 5500 01 7 1/4" 120V Circular Saw Kit...
How do I install the blade on a bosch cs10 circular saw
Their web site seems to be down at the moment but most circular saw you just need to lock the blade somehow. Sometimes putting the blade up against a piece of wood so it can't turn will get the job done. Unplug the saw so it can't run. Some saws come with a custom wrench to turn a custom bolt, others a regular combination wrench would work. There should be a bolt that goes into the center of the blade. To keep the bolt from coming out while cutting, they are reverse threaded so you loosen it by turning the bolt the reverse direction you on a normal bolt. take the bolt out and be careful you don't loose the washers on each side of the blade. Put in new blade and reverse the process of taking it apart.
Dec 02, 2009 | Bosch Circular Saw Blade, 6 1/2"
Not cutting in straight line
Normally blade overheating. Improper blade or too few teeth for material, teeth not sharp and/or offset enough for proper width of cut. Teeth must cut wider than blade. Inexpensive blades tend to do this quickly. Other possibility: Bad bearing, check for play with saw unplugged. Blade should have little wobble. Other possibility: Saw body cracked/damaged(allowing shaft to skew) or very cheap saw unable to handle material
Sep 25, 2009 | Saws
Tile saw stopped working
check the motor might have a reset botton or check the capacitor
May 31, 2008 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
