Question about Ricoh AFICIO MP 3010 COPIER. REFURBISHED. Comes with PRINT/SCAN/RADF
Sc 865 hdd error code replace - Ricoh AFICIO MP 3010 COPIER. REFURBISHED. Comes with PRINT/SCAN/RADF
3 Suggested Answers
  • 16 Answers
SOURCE: error code sc 865 -1please what is code refer to
you will need to check the hdd on your copier.
you might need to reformatt it or replace it
Posted on Jun 25, 2010
manzoorpudus
  • 13 Answers
SOURCE: Ricoh sc 672 error on new machine
  1. Go to this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
  2. Go to System Settings
  3. Go to 5875
  4. Check the setting of SP5875-001. If the setting is set to "1 (OFF)",change it to "0 (OFF)".
Try checking or changing the thermistors!
The metal contact spring on the thermistor broken causing all sorts of 'unrelated errors including 'Please Wait' sc 670 and sc 402...
Posted on Feb 29, 2012
Ricoh c6501 sp error coad sc 925 solution
SC925 B Net File function error *GW The NetFile file management on the HDD cannot be used, or a NetFile management file is corrupted and operation cannot continue. The HDDs are defective and they cannot be debugged or partitioned, so the Scan Router functions (delivery of received faxes, document capture, etc.), Web services, and other network functions cannot be used.
HDD status codes are displayed below the SC code: • Refer to the four procedures below (Recovery from SC 925). Here is a list of HDD status codes:
Display Meaning (-1) HDD not connected (-2) HDD not ready (-3) No label (-4) Partition type incorrect (-5) Error returned during label read or check (-6) Error returned during label read or check (-7) "filesystem" repair failed (-8) "filesystem" mount failed (-9) Drive does not answer command (-10) Internal kernel error (-11) Size of drive is too small (-12) Specified partition does not exist (-13) Device file does not exist
Procedure 1
If the machine shows SC codes for HDD errors (SC860 to SC865) with SC 925, do the recovery procedures for SC860 to SC865.
Procedure 2
  1. If the machine does not show one of the five HDD errors (SC860 to SC865), turn the machine power off and on.
  2. If this is not the solution for the problem, then initialize the NetFile partition on the HDD with SP5832-11 (HDD Formatting - Ridoc I/F).
    NetFiles: These are jobs printed from the document server using a PC and DeskTopBinder. Before you initialize the NetFile partition on the HDD, tell the customer:
    • Received faxes on the delivery server will be erased
    • All captured documents will be erased
    • DeskTopBinder/Print Job Manager/Desk Top Editor job history will be erased
    • Documents on the document server, and scanned documents, will not be erased.
    • The first time that the network gets access to the machine, the management information must be configured again (this will use a lot of time).
  3. Before you initialize the Netfile partition with SP5832-11, do these steps:
  4. Go into the User Tools mode and do "Delivery Settings" to print all received fax documents that are scheduled for delivery. Then erase them.
  5. In the User Tools mode, do Document Management> Batch Delete Transfer Documents.
  6. Do SP5832-11, then turn the machine power off and on.
Procedure 3
  1. If "Procedure 2" is not the solution for the problem, do SP5832-1 (HDD Formatting - All)
  2. Cycle the machine off/on.
Apr 12, 2016 | Ricoh Office Equipment & Supplies
How can I correct error code sc 981?
SC-981:Hard drive response error
check cables and format hdd. reset error. if error recurs then replace hard drive
Feb 06, 2016 | Ricoh Aficio Office Equipment & Supplies
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
MPC 2550. What is error code sc 865 01?
SC865 (HDD access error) is displayed when the power is turned ON, and SC819 (kernel stopped) is displayed when the power is turned OFF and ON.
Some broken files may be left in the HDD image disk space.
Repair by initializing the HDD image disk space (SP5-832-002).
Dec 17, 2012 | Ricoh Office Equipment & Supplies
What does error code E05-73 on my Panasonic DP-C263 mean and how can I fix it?
E5-73 is a HDD Abnormal Operation. First try turning the system off, counting to 30 and turning it back on. If it persists you want to check the HDD connections. May be a failed HDD. Panasonics exact answer is:
1. HDD connector is disconnected.
2. SC connector is disconnected.
3. HDD is defective.
4. SC PCB is defective.
Apr 10, 2012 | Office Equipment & Supplies
Error code sc 865 -1please what is code refer to
Jun 23, 2010 | Ricoh Aficio 450 Copier
Error code sc 490 and sc360
Did you try to rest the error? Do you know how too?
Feb 09, 2008 | Ricoh Aficio 450 Copier
Ricoh AFICIO MP 3010 COPIER. REFURBISHED. Comes with PRINT/SCAN/RADF Logo
20 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
