Question about Medical
Why am I smelling odd smell of rubbing alcohol no one else smells?
I smell it and no one else does!! only for a few min.
  • 2039 Answers
SOURCE: Smell
if you have a toxic smell and nothing fell on it dont use it change the heater for safety dont waste time cheers
Posted on Jan 22, 2008
SOURCE: washer smells bad
There is a door on the bottom og this machine, I opened the door to find a little spot, I placed a bowel under the spout and opened it, drained all of the liquid out and this problem stopped! I also ran the machine on hot water with bleach after I emptied this resevoir. How often you do laundry will determine how often you must empty it. For me, once every 6-8 months does the trick!
Posted on Feb 15, 2008
Bubbabear64
  • 2794 Answers
SOURCE: rubber smell, Hoover
Its your belt burning up. You have to take the bottom of the unit off to check the belt to see if it was rubbing against something or if it is broken.
Posted on Jun 30, 2008
SOURCE: Bad smell coming from heater/ smoke coming out vents
I had the same problem in my 98 Dodge Dakota! Replaced the heater core, problem solved. No more funky coolant smell and erie fog coming through my vents. I bought the heater core at rockauto.com online. Have purchased many items now from them. All factory parts so far at half the price of even AutoZone, even with the shipping. Also, you usually have to wait only a couple of days depending on the part and they have EVERYTHING.
Posted on Dec 25, 2008
SOURCE: Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
Posted on May 04, 2009
I have 1998 f150 that is sputter when driving!! Idels fine!! Makes a rubbing and roaring noise when u first take off!! Any ideas!!
It sounds like your emergency brake is on partially . Or maybe your rear brakes are adjusted too tight. Possible bad wheel bearing. Does it smooth out once you're moving? Can you smell any odd smells when this happens? Is something caught in a wheel well?
Mar 02, 2016 | Cars & Trucks
Washer shuts down after running a minute
What make is it ?
If it has a rotary style program timer it is likely this is faulty
And odd as it may sound have a smell round the dial and it may have a jacket potato smell .
Yes its true sounds a little odd but I have replaced a few and that is the Snell they give off sometimes
Jan 28, 2016 | Dishwashers
I have a 98 town car after 10-20 mins of driving it starts smelling like burning rubber from the inside i checked under the hood and there's no smell at all any ideas on what it is.
Check the tires they may be rubbing against something. Drive it until you get the smell then pull over and feel the back of each tire, if its hot you know which tire is causing the problem.
Mar 08, 2015 | Cars & Trucks
How to get rid of cigarette smell in car vents
Use air fresheners to eliminate smoke smell. After cleaning out the car, raid your pantry for odor eliminators. Dryer sheets placed under seats will help freshen the air. Also consider putting an open box of baking soda or a bowl of kitty litter in the car to absorb cigarette smell
How to Get Cigarette Smoke Smell out of Car
Apr 11, 2014 | 2003 Chevrolet TrailBlazer
Odd smell from engine
If you have been (revving the car/racing/accident/excessive speeding) you will smell something similar to burning oil from the engine, also if it has been more than 10,000kms (6000 mile) since last oil change you should get it serviced.
Dec 26, 2013 | 2005 Mercury Mariner
Odd smell when plugged in. smells almost like a lubricant or diaper cream. we've cleaned and bleached everywhere we can. it doesn't smell unless it is running and it is not inside the refrige
in the freezer behind the back inside wall of the freezer there's an evaporator fan motor that could cause this if you were smelling this inside,there's also a condenser fan motor in the back bottom of the machine that blows when it's running,pull out the machine,remove the bottom back panel and check the fan motor to see if any oil is leaking out of the motor.
Sep 15, 2012 | Estate TT18TKXKQ Top Freezer Refrigerator
White smoke and odd smell from tailpipe
maybe a rodent crawled in and it got way up into it and is stuck and it will be a while till it gets burned out? no clue. see a mechanis
Sep 07, 2012 | 1999 Dodge Intrepid
Why do perfumes smell different on different people?
Every person has different personal smell and that changes how fragrance react with the skin. You have to apply perfume without rubbing it into your skin, then wait 20 min and only at that time you will know if this fragrance for you or not.
Nov 23, 2010 | Health & Beauty
2004 Honda VFR 800 once warm starts to smell like burning rubber
Hi, Adrianhearst I would inspect the exhaust system and check the rear wheel for rubbing and pieces close to the pipes, for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
New to motorcycle maintenance Odd burning smell from front of bike started...
Weird smell coming out of Sprint
VFR800 INTERCEPTOR 2002 HONDA SERVICE REPAIR MANUAL Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda VFR800 Owner Manual
Nov 16, 2010 | 2004 Honda VFR 800
Bad smell old food in unpluged refridge
The smell has permeated the plastic, set a fresh box of baking soda in the fridge. Give it a few days and clean it with awesome or murphys oil soap. You can also use comet cleanser but if to much rubbing will scratch the plastic.
Mar 21, 2009 | Refrigerators
Medical Logo
184 people viewed this question
Top Medical Experts
Andrew Taylor
Andrew Taylor
Are you a Medical Expert? Answer questions, earn points and help others
