Question about Homedics HMDX Docking Speaker and Portable Audio System - Pink
How to fix hmdx charging port - Homedics HMDX Docking Speaker and Portable Audio System - Pink
I think the charging port on my hmdx jam wireless speaker is broken. How can I find out and of that is the problem, how can I fix it?
It should have a one year warranty. If it's older than that, it would probably cost as much to fix as a new one costs. I saw one for sale a few days ago for under $20.
May 09, 2016 | Audio Players & Recorders
Why my hx-p205a is not charging?
Your charging port might be broken like mine but there is a way to fix it
Oct 10, 2015 | Hmdx Rave Portable Rechargeable Bluetooth...
How can I change the pin or password on the hmdx rave speaker
go into your settings of phone a see if its saved an delete it then pair again.
May 09, 2015 | Hmdx Rave Portable Rechargeable Bluetooth...
How do I charge a HMDX Bluetooth speaker
Unit should have come with a usb cable. If it did not, look at what type of connector is on the speaker,(mini usb), or take the unit to your local electronics store (Radio Shack) and have them help you find the proper cable or power supply, you should be able to plug your speaker into the USB port on your computer which will then charge the batteries (if they are recharable)
Feb 15, 2015 | Hmdx Rave Bluetooth Stereo Speaker
How do I take apart an hmdx jam speaker?
The video shows how to disassemble hmdx jam speaker.
Nov 20, 2014 | HMDX Audio JAM Bluetooth Wireless Speaker...
My hmdx portable speaker stopped taking a charge
Are these powered with a battery? Is so they will need replacing. Easy job if you can use a soldering iron.
Oct 29, 2014 | Audio Players & Recorders
Can I connect my hmdx rave to my next book?
Yes, you'll need a 3.5 mm audio cable (PC audio) with M/M ends. Connect the cable between the headphone jack of the Next Book and the Aux Input of the Rave speaker. The Aux Input jack on the speaker is between the charging port and the On/Off switch. The headphone jack is between the power button and the DC Power Input port on some Next Book models; you should check your unit's documentation for the exact location. Only the volume controls on the Rave speaker will work. You'll need to select tracks and press Play/Pause on the Next Book.
I hope this helps.
Sep 29, 2014 | Tablets & eReaders
Hmdx jam troubleshooting
Maybe you turned off the wifi adapter either by a swith or function key.
Mar 08, 2014 | Computers & Internet
HMDX Jam wireless speaker cannot be paired with my computer
Go to your Bluetooth settings, go to the "Audio/Video" tab, under the "Content Protection" section uncheck the "Connect to content protection enabled headset only" and your bluetooth speaker(s) should now work.
Feb 02, 2013 | Audio Players & Recorders
Homedics HMDX Docking Speaker and Portable Audio System - Pink Logo
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
