Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
How to tighten a moen camerist facet handle - Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
dkeven
  • 62 Answers
SOURCE: Put a lever handle on the tub/shower fixture, now temp doesn't
turn the inserted part of the cartridge not the whole cartridge, you will see the cartridge has a small flat on one side of the stem reorient it opposite of where it is now and you will reverse the direction. you can do this by removing the handle only and not having to turn the water off. remove the cap and single screw and turn insert than reinstall
Posted on Jul 10, 2009
  • 49 Answers
SOURCE: My Moen kitchen faucet stopped working suddenly in
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Posted on Sep 03, 2009
SOURCE: The handle is loose
Remove the plastic red and blue insert or what ever color yours is under the handle in the front. Tighten the set screw with an allen wrench. Be careful not to over tighten or the screw will break off.
Posted on Feb 19, 2010
packrat1948
  • 528 Answers
SOURCE: How to tighten Moen Handle...Not leaking, just
There is a set screw at the base of the handle on the back side, could be alen or regular screw driver type. This link will help you find it.
http://www.moen.com/shared/pdf/7825pt.pdf
Posted on Mar 12, 2011
Testimonial: "Thiswas very helpful and very much appreciated! I saw the logo type button but did not realize it came off, although I thought it might come off. Thx!"
  • 92 Answers
SOURCE: I have a moen 7065
hey Bob
I hope you still need help, but if not I will help you anyway.
The handle has a screw that goes into a lifting cam that turns the cartiage to hot and cold. I have seen more where the black ring is broken. To fine the part needed y9ou can do one of two thing. Call Moen and they will send you all the repair part for free. IF you can not get the repair done they will send you a new faucet for free.
Yuo cab up grade the faucet and they only charge you 55.00 Not bad for a new 200.00 plus faucet.
To replace the faucet just get a basin wrench and take the water tubes off and take lose all the nuts from below. Remove the old unit and install the new one. Oh replace the water supply tubes with new one. Not worth the risk of leaving the old one in and them leaking.
Have a great day
Rich
Posted on Sep 07, 2011
How do you tighten the swivel part of moen faucet
you need to take off the handle and tighten up the bonnet nut becarefull not to damage the o-rings inside or it will leak yu just need to make sure and take care that the spout is all the way down before you crank down on the bonnet nu
May 11, 2014 | Moen 7840 Camerist Single-Handle Kitchen...
How do I get cover off moen 7840 kitchen faucet
Use a small flat-head screwdriver. Insert behind the small cover and 'pop' it off.
Dec 27, 2011 | Moen 7840 Camerist Single-Handle Kitchen...
Facet will not move left to right for both sinks hard to get it to turn
remove the handle then there is a retaining nut under that, remove the nut and as you push right to left pull up at the same time. Get smoe food grade lube and repalce as you took it a part
Best of luck
R J
Sep 05, 2011 | Moen 7840 Camerist Single-Handle Kitchen...
How to tighten Moen Handle...Not leaking, just wobbles.
Replacement parts can be found on amazon, click here and take a look: Award winning faucets and shower heads. Have a nice day
Mar 12, 2011 | Moen 7840 Camerist Single-Handle Kitchen...
Facet leaking
You can purchase a replacement cartridge for that... most hardware stores or places like Home Depot or Lowe's will have them. Take in the old acrtridge or the model of thefaucet. Some of them need a special puller to get the old cartridge out..
heatman101
Jul 11, 2010 | Moen & Villeta Two Handle Lavatory Faucet
Handle won't stay up
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Jun 05, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
May 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
I have a Moen Single Handle kitchen faucet, it's leaking at the base and below the neck (where is swivels for the faucet to move side to side). How do I fix it?
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Mar 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Handle is stiff and leaking at base. It appears I need a cartridge replacement. How do I access the cartridge? Thanks.....Keith
Moen products almost all have a lifetime warranty.  I know they have a website because I queried & found a phone number called them & got replacement guts for my unit for about $8.00, Quality counts in my book!
Jul 22, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
43 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
