Neptune won't restart
Had to pause my load & now it won't restart.
  • 641 Answers
Is your door completey shut? Just put it on drain and spin and when the water has drained restart the wash cycle, just dont add anymore soap otherwise you can over suds. Thats about all you can do. And if that doesnt work, its possible that something inside your door lock has broken and not tripping the micro switch that senses the door being shut. In that case time to call a tech.
Posted on May 12, 2014
Its flashing E3 and chiming. and stopped washing
Hi
E3 is an overload error and indicates that the washer motor is not running properly. You can take out some clothes and then restart the cycle by pressing the START/PAUSE button. After this, if the error appears again then check the motor connections, if everything appears fine then the motor should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Our Neptune Washer won't start up. It shows a Code (ol). What does this mean? We;ve tried unplugging & and Re-loading it. Still OL code.
From the FAV6800A/FAV9800A Service Manual page 14 that error code = oL Machine Paused-Load Wedging
Google this "16022808 Revision 0 December 2003" to find the Service Manual if you are going to DIY the fix.
Mar 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My neptune washer is stuck in pause mode I can't set it any any wash mode to wash a load the start/pause light just keeps blinking. Is there any way to reset it or boot it to get it started again thanks...
Karen,
Power it down by pulling the 120VAC power cord to the washer then plug back in and see if it will progress with the wash cycle. Which machine do you own the FAV6800A LED console display or the FAB9800A LCD console.
If still no good I will have you try to get into Service Mode but let’s see if a power cycle will clear the issue…….Rich
You will need the Service Manual for reference. Sears Parts Direct for reference.
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Lr shows during spin cycle and pauses washer
you need to replace the motor and the motor control board,it comes in a kit,call your parts store give them the model number and the first two on the serial.common problem with the neptune,the wire harness that plugs into the motor is strait down,moisture runs down the harness and gets into the connectors,it's around 200 bucks for the kit
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
I stopped using the "pause" button, with a little water in. Now it will not restart. I have turned completely off, yet it will not restart.
by holding the SIGNAL button for 3 seconds, the PAUSE button for 3 seconds and then walking away. It restared within about 5 seconds.
Nov 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
Aug 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Maytag frontload washer i think it's a neptune
did you clear the code (press pause /cancel twice) or unplug the unit for 2 min ?
May 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
