Question about Aiwa CDC-MP32 CD Player
Wire harnest order
I need to know the order of the pins in the rear panel. im afraid to blow out the stereo im not sure if i have the right one
    Brigadier General:
  • 6,966 Answers
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Good luck and kind regards.
Posted on Nov 04, 2007
  • Louie  Role
    Louie Role Nov 04, 2007
    Hi again,
    To clarify > "...You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester..." against the chassis/bogy/ground of the unit.
    Cheers.
Trying to hook up stereo with out harnest need to know what the pink and black wire labeled audio interrupt needs to be hooked up 2 is this why i have power but no sound im puting the deck in a 1999 ford...
Ok, before you do anything else. STOP!! You can try to find the vehicle side of the harness from the Scosche or PAC website. You run the risk of frying your entire electrical system. Hope this helps.
Aug 20, 2011 | Alpine Car Audio & Video
Replacing oem car radio/CD (Clarion PN-2165M I) from 2002 Nissan Sentra GXE. I ordered Scosche Car Stereo Connector to avoid cutting OEM connector. Im confused about the OEM Radio/CD wiring colors as to...
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
May 25, 2011 | Clarion Car Audio & Video
Need wiring diagram to show how to rewire a stereo Harnest so we can install new radio/stereo
Check this...
1996 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
Hope helps (remember comment and rated this).
Jul 30, 2010 | 1996 Ford Windstar
I need wiring diagram for in dash stereo I need to rewire harnest for after market stereo
Check this...
1992 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jul 16, 2010 | 1992 Chevrolet Cavalier
Need a wireing diagramfor toyota camry 95 for car radio the coloers dont match the new radio wire harnest
1995 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: Black/Red
Radio Amp Trigger Wire: None
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
May 05, 2010 | Car Audio & Video
Stereo wiring diagram for 91 rodeo
i you need is the wiring harnest from walmart, wire up the same colors on back of the head unit to the new harnest, then slap the new harnest to the factory harnest DONT CUT THE FACTORY HARNEST, WILL CAUSE YOU A BIG HEAD ACHE but crutchfield gives out free step by step diagrams
May 01, 2010 | Car Audio & Video
Need to know the wires to install a deck for 97
Red is power to from ignition to cd deck
Yellow is direct power from battery to cd deck to hold the memory.
Black is ground
Blue is only needed if you are hooking up an amplifier.
I always suggest buying a wire harness quick connect system for $5, then you won't have to cut origional car wiring. If by chance you are taking the original wire route, then go to installer.com to find which wires on the car are for what.
Sep 02, 2009 | 1995 Toyota Celica
How do you install it correct
the audio source's output should connect to the inputs of the TS-WX11. caution on power supply connection: don't reverse the polarity of the positive and the negative wires.
Remember also to set your HU's output in order for it to work. If it does not work yet please give the details on your HU and other devices being used.
Aug 10, 2009 | Car Audio & Video
91 oldsmobile cutlass ciera stereo wiring diagrams
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 3 1/2" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Thanks for using FixYa - A Good Rating is appreciated for answering your FREE question!!
Jul 07, 2009 | Pioneer Car Audio & Video
I need to know which factory wires are hot and ground so I can install a new radio without a wiring harness
what you are going to need is the wiring diagram... either car manual might have it or a local car audio place might have it... obviously the charge you for it... usualy for newr cars you can find it for free just by researching it on google... i found this for you duno if it helps... just code the wires and cut them to make your new bridge to the unit without a harnest
Have fun
goodluck
1991 Chevrolet Caprice Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Apr 28, 2009 | Car Audio & Video
Aiwa CDC-MP32 CD Player Logo
531 people viewed this question
Top Aiwa Car Audio & Video Experts
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
