Question about Samsung RS267TD
Samsung rs267td defrost - Samsung RS267TD
My samsung refrigerator model number RS267TD is freezing everything in the lower parts of the refrigertor and the upper part seems not as cold. Can U help?
If you wish to get some details about refrigerator common fault and troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator"...
http://electro-medical.blogspot.com/
Jan 22, 2017 | Samsung Refrigerators
RS267TD or RS265TD manual
Try manufacturer web site.
Oct 20, 2016 | Refrigerators
Rs267td refrigerator warm fridge section "noisy fan"
THE FAN IS IMPEDING AIR FLOW AND MAY HAVE AN ICE BUILD UP DUE TO A DEFROST PROBLEM? OR THE FAN PROPELLER HAS BROKEN
May 08, 2014 | Samsung RS267TD
ICE MAKER STOPPED WORKING
Make sure your freezer is set to -2. It gets messed up on samsungs at any other degree setting. There is a reset button also on the right side of the tray, underneath
Apr 05, 2014 | Samsung RS267TD
Samsung rs267tdpn beeping 11 times
Sounds like the temperature is your problem which is why it's beeping at you. The freezer is supposed to be at 0 degrees, which is well below freezing at 32. If your unit can't get down to temperature but your refrigerator is correct (38 is the ideal temperature for the refrigerator) then you have something wrong with your control board. If you keep pressing the freezer button it will go to -4 then -6, then so on until it goes positive and eventually you can scroll to 0 again. Either way if it's set to -4 it should easily be below 0 degrees. If it jumps back to the current temp, replace the control board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Samsung RS267TD
What does code 0F mean? Freezer and Frig both quit working, can you help?
Sounds like it is in display mode. It will go into display mode by pressing the lighting and freezer buttons for 3 seconds. Hold both down for another 3-5 seconds and it will start cooling.
Dec 21, 2011 | Samsung RS267TD
No food left
I suggest u take it back to the manufacture and they should give you a tempery one until its fixed if its under warntee
What is the best temperature for the freezer and fridge
There is always an optimum temperature setting marked on all fridges and it will normally be the half way mark of the thermostat.
This is quite ideal for general conditions unless you want to have a higher freezer temperature, in which case it can be set to the higher marking.
Oct 16, 2011 | Samsung RS267TD
Of error code on display screen. how do I fix it?
If your control panel displays "OF" instead of the temperature, your refrigerator is in "Cooling Off" mode. In Cooling Off mode, the refrigerator appears to be running normally, but the compressor is off so the unit does not cool. Cooling Off mode is used by retailers to save electricity when the refrigerator is on the showroom floor.
Note: Cooling Off mode is also called Demo mode or Exhibition mode.
Depending on your refrigerator, to remove your refrigerator from Cooling Off mode:
  • Either press and hold the Energy Saver and Power Freeze buttons for 3 seconds
  • Or press and hold the Power Freeze and Freezer buttons for 3 seconds.
The temperature display re-appears after the unit is out of Cooling Off mode.
Aug 21, 2011 | Samsung RS267TD
Samsung RS267TD Logo
88 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
