Question about Dell UltraSharp 2408WFP 24" LCD Monitor
2408 wfp disassemble
I have a Fun time 2408 machine we ended up using different pre made popcorn bags and oil 4 6 and 12 and were just now realizing that weve been using the wrong oz,s and when we do it make crappy pop co
You can clip the corner of the popcorn section and shake the salt into a small bowl, then cut just the corn section into another bowl, and hand measure the ingredients.
The Funpop 8 works best with 2oz (1/4 cup) oil, 8oz (1 cup) popcorn, and 1 teaspoon of salt.
Jul 01, 2014 | Gold Medal 2408 Popcorn Maker
Do you do popcorn machine 8oz stirring rod please?
Your question has more questions than answers. You choose a Gold Medal 2408 Popcorn popper as your model, but it does not have a 60ktyz motor, the stir rod and shaft are separate from the motor, and you can't get parts for it on ebay.
What model machine do you have?
Feb 19, 2013 | Gold Medal 2408 Popcorn Maker
I have a Gold Medal Fun Pop 2408 popcorn machine and it does not seem to get very hot. It takes for ever to work. It didn't used to be that way. Whats wrong.
The thermostat likely may be bad.
Gold Medal has an excellent online support to buy parts and they even offer live chat during business hours (see website). Their toll-free number is: 1-800-543-0862 .
Parts that are available (for the 2408) to buy online:
http://www.gmpopcorn.com/store/Results.cfm?category=5&secondary=26&keywords2=&Submit=Search
Good luck.
Mar 02, 2011 | Vacuums
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
Dell 2407 WFP monitor Flash Memory Card Reader does not
if on the card it is written SDHC then it means that the card reader doesn't support SDHC cards, for 100% compatibility try a 2/4 Gb card with only SD markings on it not SDHC.
May 25, 2010 | Dell Computers & Internet
Use hdmi out on 2408 display
No, won't work as teh monitor does not have sound capabilities. However, this will work if you have some sound input into the monitor, like if you use the HDMI (which includes sound) to send signals to the monitor, instead of the VGA / DVI connector. (All sound output on a system is from the sound card on the system only, monitor sound options are usually just an extension of the same)
Jan 07, 2009 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Error 2408
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Dell UltraSharp 2408WFP 24" LCD Monitor Logo
52 people viewed this question
Alun Cox
