Question about Krups Orchestro Dialog FNF2 Espresso Machine
Krups xp7200 error code 06 - Krups Orchestro Dialog FNF2 Espresso Machine
4 Suggested Answers
SOURCE: Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Posted on Sep 27, 2008
SOURCE: krups xp 7240 cofee machine
for the error code 06. (this is what I got from a guy on a tech support line)
The issue is with the waterfilter. If you haven't changed it for a long time - change it. If you recently got a new one follow these steps:
- take the filter out
- unplug the machine from electricity
- plug it back in
- install filter (go into prog- service- install new filter)
It should remove the error. Haven't tested that yet, but that's what I got :)
Good luck
Posted on Apr 27, 2009
espressonist
  • 1711 Answers
SOURCE: I have a problem with my Krups XP7240, it is
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
Posted on May 10, 2010
Error code 06 on Krups xpt 7240
Look for and remedy any internal leaks. If error 6 remains then expect to replace the distributor assembly.
Aug 20, 2014 | Krups XP Coffee Makers & Espresso Machines
Error code 06
Look for the leakage source:hoses, actuator, priming valve?
Switch or distributor switch control fault: incorrect detection of cams error in distributor position in cylinder descent phase.
Flowmeter hoses changed over
Distributor problem (leakage at
drain ..)
Faulty connection between the
2 picto boards
If no leak detected, replace
power board V26 with V29
Jul 08, 2014 | Krups XP7260 Espresso Machine
Krups xp7200 how to do descaling
Manual has procedure....read that section.
Jan 24, 2013 | Keurig B50 Coffee Maker
May 10, 2010 | Krups Small Appliances Espresso Machine
Krups XP7200 series date problem
It seems that the dial knob and the electronic opto coupler don't work anu more. You can replace the digital panel by try to find a broken machine on ebay. Unless you are an electronics engineer like me (you can try to replace the optocoupler). See the post on leaking xp7240 for opening up the machine... it's tricky but easy.
Apr 14, 2010 | Krups XP7230 Compact Super Automatic...
Error code 06 on a Krup XP7245
remove calk-filter in watercontainer..
Jun 28, 2009 | Krups XP7230 Compact Super Automatic...
Error code 06
The error 06 happens because one of the services – Rinsing, Cleaning, Descaling or Replace Water Filter is out of date.
Start in a sequence and go through ALL services. Go to “Machine Information” in “Programme” Mode to ensure that “Last” reads zero or a maximum of something below 10 and your machine will NO longer give start up problem. Please report it if this still occurs, because a computer reset can be done.
Mar 13, 2009 | Krups Small Appliances Espresso Machine
Krups xp 7240 cofee machine says error code 06
- plug it back in
Good luck
Nov 01, 2008 | Krups Small Appliances Espresso Machine
Good Luck.
-Steve
Sep 27, 2008 | Krups XP7230 Compact Super Automatic...
Krups Orchestro Dialog FNF2 Espresso Machine Logo
100 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
