Sirius sportster why does it keep updating but not play after update?
My sportster will update then only display channel like Howard 100 in conner but nothing on main screen it will play for a few sec then update again & again
SOURCE: Display "Updating"
I am having the same issue with my Eclipse radio with Sirius. I called my installer - Al & Ed's - this was the first that they have heard of this. This suggested that the unit be powered down - disconnected and reconnect the power - but warned me that all of the presets would be lost.
I am going to take it in and have them do that. I will re-post re the outcome.
Very frustrating.
Posted on Nov 20, 2007
SOURCE: SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Posted on Aug 12, 2008
SOURCE: Sirius Sportster
Look at the bottom of your unit, you'll notice the round port next to the slot? It get's jammed up inside the unit if you pressed to hard setting it into the cradle at some point. Not easy to fix, unfortunatley.
Posted on Sep 29, 2008
SOURCE: Clarion SIRIUS Radio Receiver - Not Receiving All Subscribed Channels
My DX445 does the same thing. Here's my method for fixing it, it should work for any similar Clarion receiver:
1. If possible, make sure the radio is turned off when disconnecting the battery. If the radio turns itself on when the vehicle is restarted (for example after jump starting or battery disconnect for a few seconds only), turn the radio off.
2. Disconnect the battery by removing the negative battery cable from the battery. Leave it disconnected.
NOTE: Car batteries can be dangerous things. If you're unsure how to do this safely, get an experiences mechanic to help you.
3. Reset the radio. On my radio this is done by removing the faceplated, and pressing a tiny button for 30 seconds. Your radio may be different.
4. After waiting at least 20 minutes, reconnect the battery.
5. My radio displayes 'System Check -- Press Power'. After pressing the power button, the display reverts to the clock.
6. Turn on the radio. It should work fine on the broadcast bands.
7. Select 'Sirius'. The radio should display 'Updating'. Don't touch anything until the radio finishes its update phase. When it's done, it should tune to Sirius channel 1 and play as normal.
8. This should restore normal tuning. reset your presets and preferences.
What seems to happen is that the radio gets stuck in a 'Category Select' condition, but not all the categories will load, and manual tuning will not allow, say, Radio Classics to play when the radio is stuck in Pop mode.
On occasion (maybe 1 time out of 10), the radio hangs while doing the 'updating' in Sirius mode. If this happens, just shut off the radio and start over. I've never had to do the brute force reset more than twice since I stumbled on this method.
Posted on Dec 09, 2008
SOURCE: Stiletto 100 problem. it says "No Channels available"
I am having the same exact problem!!!
Posted on Aug 04, 2009
Shows "updating". Never completes. Pulled power plug and retried. No help. Displays channel 0 until antenna is pluged in then updating. Displays "antenna failure" if antenna is unpluged during "updating".
Oct 11, 2010 | Pioneer SIR-PNR2 SIRIUS Radio Receiver
Sirius S50 "No channels available"
I had the exact same problem happen to me yesterday with my S50. My guess is that the software got corrupted somehow. I fixed mine last night be reinstalling S50 software via USB cable to my PC. Note: You need My Sirius Studio application loaded on your PC. Be sure to press Exit button on My Sirius Software Ap after you reinstall S/W. Patiently wait for S50 to 100% complete before disconnecting. Then, manually turn on S50 (while holding in your hand); do NOT put in car/home dock yet. S50 will then update S/W. When this completes, now you can put in dock. I don't exactly recall, but I think the S50 indicated the dock was being updated, then it defaulted to channel 184 indicating to call Sirius to subscribe. Since I already have a subscription in place on my S50, I just pressed channel 2 (The Blend) from my remote, and then my S50 began updating all channels. Success! I'm so happy my S50 is now working again! Good luck to others experiencing same problem; hope this helps! I can only imagine the frustration trying to get help from Sirius folks for this type of problem...
Jun 24, 2010 | Sirius Satellite Radio S50-TK1 Satellite...
All of a sudden the display says invalid channel and 0% updating channels sirius says the radio must be broken
I would try a different antenna first, then exchange radio if that doesn't work. You will have to 'update' the radio for about 30 minutes after you first activate it, but after 30 minutes it should be fine. Try the activation channel (channel 1) - call Sirius for a 'refresh'. After 30 minutes, your undate should be done. Turn the radio off with the pushbutton on the radio. Turn it back on - should be no more updating. If so, then there is a problem.
Dec 29, 2009 | Sirius Starmate ST2 Satellite Radio...
My receiver displays "updating channels" and nothing else works
problem lies with sirius, contact sirius and follow instructions to update exactly step by step...
Sep 20, 2009 | Sirius Satellite Radio Receiver
AVN5500 - Display stuck at "Updating" when using Sirius.
yes it is the sirius unit I was told to drop all power while system is on disconect the battery while ignition is on then turn back on and wait ten min for update to complete if that does not work call sirius to have them send the update mabe they can tell you when its complete hope this helps..
Aug 07, 2008 | Eclipse AVN5500 Car DVD Player
I'm recieving a strong signal on my stiletto 2 but no sound on the radio. The MP3 player works with headphones and so does internet radio.
You need the firmware upgrade from the Sirius website:
Bug Fixes
· Reduced incidence of “acquiring signal” and “antenna not detected” messages
while the radio is installed in the Stiletto Vehicle dock (SLV2)
· Improved audio quality and distortion reduction
· Reduced incidence of long block recording and Radio Replay corruption
How to Get this Release
Updating over WiFi:
Subscribers may update Stiletto 2 over WiFi by following these steps:
1. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
2. Turn on the Stiletto 2 and press the HOME button
3. Use the MEDIA DIAL to scroll to Internet Radio
4. Press the SELECT button to connect to Internet Radio
5. Tune to your favorite station and let it play for several hours.
6. Follow prompts on screen to complete the update, then power cycle your radio to
apply the updates.
7. Next go to HomeSettingsDeviceDevice info, if the baseband version is
already 00.14.94 you are done. If not, continue to the next step.
8. Reconnect to Internet Radio and listen for at least 15 minutes.
9. Disconnect, and tune to Satellite Radio. Updating Sirius will be displayed for
approximately 5 minutes.
10. Once the message clears, your update should be complete. Go to the Device
Info screen to verify the update has been successful.
Updating using My Sirius Studio™:
Customers without WiFi access may update using My Sirius Studio™ running on a PC
with an active internet connection:
1. Launch My Sirius Studio™ on your computer. Be sure you are running the latest
version of My Sirius Studio, currently version 1.5.1.
2. Power cycle the Stiletto 2 by holding the power/lock switch down for 5 seconds
and releasing.
3. Turn on the Stiletto 2 and connect it to your computer using the USB cable
supplied with your device
4. In My Sirius Studio, click on the gear icon next to the device or go to File
Device Settings Check for Software Update.
5. Follow the instructions that appear in My Sirius Studio™ to complete the update.
Please Note: During the update, your media library must be re-built. If you have a
large amount of content stored or a microSD™ card installed, the process can last
for as long as 10 minutes. During this time the message “updating media library” or
may be displayed.
6. After disconnecting from your PC it will be necessary to power cycle your Stiletto
and connect to Satellite Radio to refresh your channel list.
For additional questions regarding your Stiletto 2 or the SIRIUS service, please refer to
the product manuals. You can also reach the dedicated Stiletto Technical Support Team
at 1-800-869-5364 from 10 AM to 10 PM Eastern Time Monday through Saturday, or by
email at customercare@sirius-radio.com.
Jul 06, 2008 | Audio Players & Recorders
Stiletto 100 recorded content skips
Double check your signal strength during the time of day your recording sounds like classic signal drop. Could also be software issue or memory issue. As a last resort; SIRIUS Device Recovery (SDR) is a software application that helps you recover your Stiletto (SL2, SL100 or SL10) in the event of a complete system failure.
The SIRIUS Device Recovery program retrieves the latest version of software for your Stiletto from the Sirius website. NOTE: Performing device recovery WILL ERASE the entire contents on your Stiletto: all music, Sirius recordings, channel presets and any user preferences. The Stiletto will be reset to its original factory state. You can perform the revovery from the Sirius Studio software that came with your device or http://www.sirius.com/mysiriusstudio
Jan 19, 2008 | Sirius STILETTO 100 MP3 Player
Display "Updating"
Very frustrating.
Aug 13, 2007 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
 Grubhead
Grubhead
